Featured 2020 Toyota Supra: The Aftermarket Parts Tuners' Take
Discussion in 'General Supra Topics' started by AsupramkvC, Apr 12, 2019.
  1. AsupramkvC
    AsupramkvC Well-Known Member
    First Name:
    Gerich
    Car(s):
    86
    Nov 11, 2018
    Philippines, USA, Japan
    324
    Liked:
    301
    Aftermarket tuners find the 2020 Toyota Supra a promising sports car platform.
    .....and according to Paul Pilpa, sales and marketing for Tein USA, "Completely left alone, it is an already very capable sports car," of the Supra and its suspension.
    https://www.motortrend.com/news/2020-toyota-supra-aftermarket-take/
    2020 TOYOTA SUPRA: THE AFTERMARKET’S TAKE
    Performance parts makers share their first impressions of the Mk V
    April 12, 2019
    Given the history of the nameplate, the 2020 Toyota Supra has some very big shoes to fill—especially for the enthusiast community that worships the previous Mk IV Supra like a four-wheeled, boost-hungry god. This new Supra is undoubtedly very different from the last, but inquiring minds still want to know: How will it take to modifications? At the Supra measuring session held at the SEMA Garage in Diamond Bar, California, we spoke with the aftermarket companies designing parts for the Mk V to get their opinion on the highly anticipated sports car.
    A GREAT PACKAGE FROM THE FACTORY
    The companies that attended the measuring session each had their own areas of expertise, but all agreed that the Supra looks pretty well designed right out of the box. Engineers from performance brake specialist AP Racing said the Supra's stock brakes, which include four-piston Brembo calipers and 13.7-inch discs up front, should be plenty capable for most owners. Representatives from Stoptech had similar impressions, saying the stock setup, though heavy, appears to have been designed to deliver a mix of performance, durability, and low noise.
    The front strut, rear multilink suspension with electronically controlled dampers also shows promise. "Completely left alone, it is an already very capable sports car," said Paul Pilpa, sales and marketing manager for Tein USA, of the Supra and its suspension. Tein built the suspension for the Supra pace car that you'll see at NASCAR races this season.
    One account of the Supra's out-of-the-box performance comes from pro driver Craig Stanton, who drove a preproduction version of the car in support of a Toyota event at Texas Motor Speedway. Stanton said the Supra felt comfortable for him right away, and he found it easy to drive quickly around the track and gradually shave time off his laps. (We drove a Supra prototype last summer, and we look forward to driving a production-spec Supra next month.) A good sign that the Supra is fit for track duty: After a dozen or so laps, Stanton came in for a driver swap, inspected the brakes and tires, and went back out on track for another round of brake-fade-free driving. He says the average owner is going to love the Supra as is. But as many would tell me, there's always room for improvement.
    STRONGER, FASTER … BETTER?
    Just like its predecessor, the 2020 Toyota Supra will have a wealth of aftermarket parts available. But owners will have to decide what aspects of the stock car are most important to them before choosing what to modify and how much. If they want an all-out race car, then there's no need to hold back. But if they're hoping to preserve the Supra's ride comfort on the street, compromises will have to be made. Aftermarket suspension systems can work with the stock electronic dampers, but performance gains will be smaller.
    "Considering the level of OEM chassis refinement here, the improvements may be limited," Jeff Cheechov, president of Progress Group, said in an email. "Damper or coil-over installations will likely require a black-box interface or similar integration to restore the functionality of the ride control system."
    On the other hand, going with a full coil-over setup will sacrifice ride quality, according to Dan Gardner, founder of DG-Spec, a close Toyota performance partner. A lower ride height combined with stiffer springs might cut 1.0 to 1.5 seconds off your lap time, but the ride will be much less forgiving on the street. There's always a risk of disrupting the harmony of the chassis, he says, so if you change one thing, you may need to take appropriate measures elsewhere to maintain that balance.
    But if you're looking to shed weight at the corners, there should be plenty of savings to be had with an aftermarket brake kit. The front rotors weigh 25-plus pounds each, despite having riveted aluminum hats. It's unclear how much of that mass is needed to stop the car and how much is for durability, but Erik Steinkamp and Tyler Hauptman of Stoptech see potential weight savings to be had in an aftermarket disc and caliper. In addition to shedding precious unsprung weight, a Stoptech system would also increase heat capacity and pedal feel thanks to braided stainless steel brake lines, they say.
    The Toyota Supra makes 335 hp and 365 lb-ft of torque from its BMW-sourced 3.0-liter turbocharged inline-six. That felt like enough to Stanton during his time on track, but those who want more can rest assured that ECU tunes are in the works.
    CHALLENGES AND QUIRKS
    Although everyone had positive things to say about the Supra's design, they did point out potential pain points for both aftermarket developers and the folks who will eventually work on the car. Because it was codeveloped by Toyota and BMW, the Supra uses a number of fasteners more commonly found on European cars—not surprisingly including BMWs. Mechanics more familiar with working on Toyotas will have to dust off their E-Torx socket sets and also get used to mounting wheels using the German-favored lug bolts instead of studs. Those aren't necessarily disadvantages, just things owners and technicians will have to get used to.
    As we already covered, the electronic dampers can be retained in an aftermarket suspension setup. But if you want to go with a full coil-over kit including new dampers, you'll have to disconnect all the electronic bits. Doing so issues a warning that isn't easily bypassed, so suspension companies like Tein are devising canceller systems to include with their kits. That's a problem you'd have on any modern car with an electronically adjustable suspension, however.
    One issue more unique to the Supra (and likely the Z4) is the position of the rear anti-roll bar. The bar connects to the top of the rear subframe and would require removing virtually everything below it to replace. The rear bar also poses potential clearance issues for companies designing two- or three-way adjustable dampers, according to Tein's Paul Pilpa, as it may get in the way of a remote reservoir. But that's why SEMA hosts measuring sessions like this—to give parts developers a chance to identify challenges early and come up with workarounds.
    Like many modern cars, the Supra uses an electronic parking brake, which places a solenoid on the rear caliper that engages at the press of a switch. The experts from Stoptech say a rear big brake upgrade that keeps the electronic parking brake intact is technically possible but probably not worth the cost to develop. The percentage of owners who plan to modify the rear brakes is likely pretty small, and those who do want to will probably go with a racing setup that deletes the parking brake anyway.
    THE OVERALL REACTION
    When the 2020 Toyota Supra made its debut earlier this year in Detroit, reactions online were mixed to say the least. But everyone I talked to at the SEMA event seemed genuinely excited about the car. Even if it is mostly a BMW under the skin, this new Supra shows a lot of potential. It's hard to say how many owners will choose to modify their Supras, but you can count on the Mk V being a popular car at this year's SEMA Show. We can't wait to see what tuners can do with this promising sports car platform.
  2. spamthechan
    spamthechan Well-Known Member
    First Name:
    Car(s):
    Toyota Prius V, Porsche Boxster
    Jan 13, 2019
    Louisville, KY
    98
    Liked:
    241
    Great article. Sounds like springs and new front rotors will be a good place to start with this car.
  3. OP
    AsupramkvC
    First Name:
    Gerich
    Car(s):
    86
    Nov 11, 2018
    324
    Liked:
    301
    Well, that would be cool! By replacing the front rotors with drilled and slotted or vented ones will definitely put the Supra in a different braking category. Springs....not sure if it will affect the electronic suspension setup once modified.
    I’d also want to figure out about those fake plastic bits all over the car, if those could have any actual use in order to help the car in terms of aerodynamics, as well as cooling the brakes, and performance enhancement too.
  4. spamthechan
    First Name:
    Car(s):
    Jan 13, 2019
    Louisville, KY
    98
    Liked:
    241
    Per the MT article:
    "Aftermarket suspension systems can work with the stock electronic dampers, but performance gains will be smaller... Damper or coil-over installations will likely require a black-box interface or similar integration to restore the functionality of the ride control system."
  5. kona61
    kona61 Well-Known Member
    First Name:
    J
    Car(s):
    2018 4Runner Off-Road, 2017 Mk7 Golf TSI, 2016 Porsche Cayman GT4, 2020 AZW Supra on Order
    Mar 25, 2018
    Redlands, CA
    403
    Liked:
    634
    Not really sure what that means, but on VW, Porsches, and especially BMWs, when you put on aftermarket coilovers, there are two ways you can get rid of damper errors.
    1. You can buy four little modules that plug into the stock damper connections and it tricks the car into thinking the damper is still there.
    2. You can code the electronic dampers out of the car's DME/ECU.
    KahnBB6 and mas921 like this.
  6. spamthechan
    First Name:
    Car(s):
    Jan 13, 2019
    Louisville, KY
    98
    Liked:
    241
    Aftermarket systems that work with stock dampers, I think, simply means lowering springs.
    The MT article states coilovers will need black boxes to work ala stock, or trick the ECU, like you mentioned.
    KahnBB6 and kona61 like this.
  7. kappa_md
    kappa_md New Member
    First Name:
    John Paul
    Car(s):
    2017 Toyota 86 (White), 2013 Toyota Corolla Altis (Silver), 2013 Toyota Yaris (Black)
    Aug 16, 2018
    Manila, Philippines
    Liked:
    Lowering springs is the way to go Upgraded brake pads and rotors once stock ones are faded. Probably great setup out of the box
  8. KahnBB6
    KahnBB6 Well-Known Member
    Car(s):
    '93 Lexus SC300 5-speed 2JZGTE R154 LSD
    Aug 24, 2018
    145
    Liked:
    304
    The way this article reads I guess the one thing the different tuner and parts manufacturer outfits weren't allowed to do is strap one of the Supras to a dyno to measure the true wheel horsepower. In some of those shots I saw a couple of laptops out and I do wonder if any of those groups were able to do any CAN message stream captures from the OBD2 port to better understand the various systems and possibly the engine ECU itself. Probably not but its possible that someone tried.
  9. kona61
    First Name:
    J
    Car(s):
    Mar 25, 2018
    Redlands, CA
    403
    Liked:
    634
    From what I've heard, the B58B30M1 has tweaked tables from prior B58's which means the tuners will have to create new tunes for the cars running this engine. I think that the actual encryption protocols and such are the same, however.
    KahnBB6 likes this.
  10. Nurburgring
    Nurburgring Well-Known Member
    Car(s):
    911 Turbo, M3 E46, Turbocharged NA Miata, S2000, Mazda FC3S & FD3S, EP91 Starlet, EK9 Type R, EG6 Sir2, AE86, 3SGE AE86, Evo7RS, F3 race car
    May 3, 2018
    Chile
    182
    Liked:
    758
    #10 May 16, 2019 at 2:02 PM
    Sorry, repost. Mods delete please.
Share This Page
Loading...
