27 lbs of boost?!
A90313
Mid Atlantic
2020 supra
Was driving my Supra with pureturbo800 and downpipe this evening.
happened to have to MhD hooked up on manual logging.
If you are familiar with the MHD logger it records max and min values. After a pull I looked down and it said my max boost was 27 lbs. target boost was 21 lbs. it also took out 5 degrees of timing.
of course I didnā€™t have AFR gauge on. No clue why I had gear indicator instead
Does this sound even close to correct?
93 octane tune. No meth
wgr73
New Mexico
2020 GR
On throttle closure (when you let off the pedal) you sometimes get a boost spike that will register as a very high number
A90313
Mid Atlantic
2020 supra
makes sense to me. Thanks. Will be able to sleep tonight
Allday420
Dan
Htown
2020 Supra, 2015 wrx, 1992 Land cruiser diesel
Iā€™m also about to install the pure800. Curious what tune youā€™re running on?
ST-AUTOSPORT
Tonni
Belgium
Supra MKV, Lexus IS300, Celica GT-4 ST205 WRC, MR2 SW20,
seems right, however i would log afr and knock as it took out 5 degrees.
Twisted Tuning
www.twistedtuning.com
The min/max reading is not indicative of if you were actually running that much boost. As stated.. when you let off. It could have been that. Or ypu were overboosting at the shift or spiking at the shift
tadda
Tom
Arizona
..."If you are familiar with the MHD logger it records max and min values. After a pull I looked down and it said my max boost was 27 lbs. target boost was 21 lbs. it also took out 5 degrees of timing... "
I'm curious as to why your pulling 5 degrees of timing?? Have you logged knock count to see if this is an issue?
tisdrew
BMW 335i, Kouki s14
If you're not uploading logs to datazap for review, are you even logging? lol
