A word of caution for meth injection sprayed through the throttle body...
Camus
Daniel.
Elk Grove, California
2020 GR Supra , 2006 Z4M Roadster, Accord 15 v6 - 6, Mini S 2020.
Not to scare people or trying to cause panic or judge people using this setup. Just sharing some information, that may be useful.
This fellow blown his B58, the culprit seems to be running lean in some cylinders while spraying meth:
This is the main reason I would go port injection instead, some tuners had mentioned this problem before.
a90moe
Earth
MKV Supra
As long as methanol is for cooling purposes there is no such risk
Once it gets used to boost fuel with timing adjustments then yes, 100% correct
Draven83
chris
Missouri
2020 mkv, 2013 2j swapped frs
1 and 6 go lean. 2 cars have already blown from it.
Advertisement
Advertisement
