A90 Transmission Potential
T56283
Japan
2034 Toyota Celica
I'm not finding a lot yet on the specifics of this new transmission and what sort of horsepower and toque limits it might have. I think the B58 variant going in the new Supra will be a solid motor but I'm not finding the same wealth of information on the transmission but maybe someone here knows more.
kona61
Josh
San Bernardino-ish, CA
I'm not finding a lot yet on the specifics of this new transmission and what sort of horsepower and toque limits it might have. I think the B58 variant going in the new Supra will be a solid motor but I'm not finding the same wealth of information on the transmission but maybe somewhere here knows more.
It is a Zf8HP. Probably the most ubiquitous transmission in the world. It’s tough, but it depends on which variant is being used in the car.
Guff
Moderator
Staff member
Moderator
A80, A90, Mk1 Celica
The Supra should be using the latest revision of the ZF 8HP50, which is technically the version that is rated to 500NM of torque, which is (suprise, surprise) 369lbft of torque, aka the exact number that the B58 is rated to lol. Does that mean that the trans will explode on a cool day when the engine makes 370lbft? No, of course not, the ratings themselves are somewhat arbitrary at this point and are used to distinguish between the model ranges.
I have read that the code on the Supra trans is 8HP51, which might signify the revision model, but I'm not sure. Either way, it's a torque converter automatic, so it should do fine with a little power bump. Other BMW guys seem to be pushing 400-430lbft through their cars with a TCU flash to boost line pressure, and nobody has had issues yet. The 8HP is a fairly modular design so I'm sure there will be a relatively straightforward upgrade path for it as well.
My interest is in the 8HP's hybrid motor integration. Would be very cool to see an aftermarket solution to adding in hybrid power to the Supra, but that's quite a lofty goal.
McWicked
Stutz Bearcat
I'd definitely click on the Supra Hybrid Build Thread :p
"I need a little help. Does anyone know how to completely disable the regenerative breaking feature on the Prius C ECM? It's the Denso 9990 if that helps. Thanks!"
MA617M
lots
Two things to note
- A planetary gearset is inherently strong by design that a spur gear arrangement
- The V160 and T56 are only rated to 450NM
Source: I work in the aftermarket sequential transmission industry. We will aim to deliver the first sequential Transmission kit for the A90 in the world.
kona61
Josh
Two things to note
Do you work for Holinger?
McWicked
Stutz Bearcat
Holy Crap! Now THAT would be fun...
roo-roo-roo-wurrrrr *BANG* wuurrRRRR *BANG* WUURRRRRRRRR!!!! *BANG* VROO-VROOO-VROOOOM!!!
Hell, I wouldn't even go anywhere. Just sit in the garage making the sound effects.
tisdrew
BMW 335i, Kouki s14
Illsic_Design
Josh
Nor-Cal
Let's just say that the 6hp21(rated for 332 ft lb) in my 09 335i is still going pretty well at 182k with 440 ft lbs running through it. ZF transmissions are pretty strong, and the newer 8HP's are only better then the previous 6hp's.
Bflood
Columbus OH
3.0 Premium
Two things to note
It's been a couple years now, have you got any more info on this?
