Anyone running a 315/30/19..?
TrailLaser
JE
Houston
'55 210, '06 TBSS, '18 Sierra, '23 ZX-4RR, '24 Supra 3.0
Got mine in today... Installing HKS Hipermax S coilovers this weekend and will be installing the new rim/tire combo next week.. Get the drop dialed in and then alignment..
19x9.5 & 19x11 - My design custom built by VT Forged..
** 3/20/2025 - Snapped a couple pics today, getting it settled before alignment..
** 3/31/2025 - Couple pics today after getting it aligned by @D3Motorsports.. No rubbing, everything back in spec now.. Time to enjoy..
Damn you’re going to be steamrollin‘…. You must be running some BIG power. Just don’t turn the wheel and you should be fine 🫣
Edit: whew 😅 …. Realized that only in the rear. That‘s some serious grip!
Hardac_
A
2022 GR Supra
I'm running 305/30-19 in the rear. 315 will be quite a squeeze but will hopefully work. My wheels for reference on stock springs.
Hardac_
A
2022 GR Supra
whats the wheel width?
My bad, same as OP. For the full specs,
Apex vs-5rs
Front 19x9.5
Rear 19x11
Michelin Pilot Sport 4S
Front 265/35-19
Rear 305/30-19
Erty
Edward
'24 Supra 3.0 Premium MT
Did you ever get them on? pics?
TrailLaser
TrailLaser
JE
Houston
TrailLaser
TrailLaser
JE
Houston
Arrived a day early..! Matches rims perfectly, high quality, highly recommend tpmsbargins..
TrailLaser
TrailLaser
JE
Houston
Tires are mounted, studs are done along with front suspension/cancellers, hopefully wrapping up the rear suspension tomorrow..
Erty
Edward
Those 315 Michelins looking good! I might make the switch my 305's are almost done, I have the same wheel specs
AJRMKV
2023 Manual Supra
ET35 on the rear?
How much camber are you running?
TrailLaser
TrailLaser
JE
Houston
Hopefully here in a few hours I'll have it done, fingers crossed no rub..
ET35 on the rear?
Yes on the 35.. I'm installing the eibach camber arms now as well.. I'm going to make one full thread turn longer than factory arm, should help till it's actually aligned..
TrailLaser
TrailLaser
JE
Houston
Its official, they fit..!
I can tell my camber is off, but that's a good thing.. I've got about 3~4mm of clearance, but once camber is adjusted (will kick top of wheel outword), it will be perfect..
Gonna take some short trips to settle the suspension, then off for alignment.. I'll post up some better pics once its out in the wild..
