Auto Talent | IND Painted Reflector Kit
Discussion in 'Cosmetic Mods (Interior/Exterior/Lighting)' started by AutoTalent, Nov 13, 2019.
  1. AutoTalent
    AutoTalent Active Member
    First Name:
    Golan
    Car(s):
    R8 Gen 1 6mt
    Oct 22, 2019
    Liked:
    21
    #1 Nov 13, 2019
    [​IMG]
    [​IMG]
    Every detail of your new 2020+ Supra is a chance to make an impression; that’s where IND’s painted reflectors come in. Everything about these reflectors exude quality, from the OEM cores (manufactured in Germany) to the factory matched Supra-specific paints. Crafted by a staff with a combined 30+ years of experience, each reflector is meticulously hand sanded, primed, painted and cleared exactly as we would with our iconic BMW cosmetic program. The icing on the cake? Each reflector set is polished with Rupes equipment and lovingly finished with a coat of Adam’s paint sealant, ensuring each set arrives in pristine condition. Don’t settle for the ordinary. Bring out the best in your A90 Supra with IND’s painted reflectors. *Limited Availability*
    Product Details:
    • Sold as a pair, full replacement of OE reflectors
    • Compatible with all A90 Supra models
    • OEM base for flawless factory fit
    • Paint quality guarantee with high quality finishing and quality control
    • Ceramic Pro 9H coating (optional)
    About IND: IND has made its stellar reputation known throughout the BMW community with an unwavering commitment to curate or create the finest components possible and provide our clients an honest and personalized consultation based on sound facts. Since our founding, we have worked hard to successfully support our vast distribution network with unprecedented access to coveted components and we look forward to serving the Supra community in this very way.
    Optional Add-On: Ceramic Pro 9H Permanent Bond Nanoceramic Protective Coating – Two layers are pre-applied before shipment
    Ceramic Pro 9H forms a permanent bond with the surface and will not wash off or break down. It is a highly durable protective coating that protects your vehicle's paintwork or any other surface from damaging contaminants. The unique formula of Ceramic Pro 9H allows it to be applied in multiple layers which means the thickness of the coating can be increased with additional layers, allowing a thicker/harder coating with improved scratch resistance.
    HATED1 and EastCoastSupra like this.
  2. HATED1
    HATED1 Well-Known Member
    First Name:
    Bernie
    Car(s):
    86, 370z, 350z, 240sx
    Feb 14, 2019
    Washington State
    61
    Liked:
    32
    Can you PM me pricing for a pair in Red shipped to 98516, Thank you.
  3. SUPRATOY
    SUPRATOY Well-Known Member
    First Name:
    Luis
    Car(s):
    2020 SUPRA
    Aug 2, 2019
    48
    Liked:
    PM you for info.... interested on a full set!
  4. 2k20HTownMKV
    2k20HTownMKV Well-Known Member
    First Name:
    Joe
    Car(s):
    Nov 2, 2019
    Houston
    64
    Liked:
    26
    Occupation:
    Technology Manager
    PM sent
  5. OP
    AutoTalent
    First Name:
    Golan
    Car(s):
    R8 Gen 1 6mt
    Oct 22, 2019
    Liked:
    21
    All PMs replied!
  6. Trojan1992
    Trojan1992 Well-Known Member
    First Name:
    Jon
    Car(s):
    RS3, GT3, TRD Pro 4Runner and JCW Mini Cooper
    Aug 2, 2019
    Newport Beach
    114
    Liked:
    156
    As you guys know, I did this when I got my car, not from this vendor my local shop painted them for 25 dollars ( sanded too) but I am replying to let you guys know you have to partially remove your front bumper to get the old ones off. The tape/glue BMW uses is a nightmare and it was a PITA to get the old stuff off but it was worth the morning to do this. Becareful on all the plastic fasteners, they are factory tight and when you pop them they explode out.
    TWiTCHY and HATED1 like this.
  7. 2k20HTownMKV
    First Name:
    Joe
    Car(s):
    Nov 2, 2019
    Houston
    64
    Liked:
    26
    Occupation:
    Technology Manager
    Should be possible to maybe turn the wheels and use a jack to raise the car up and then heat gun on the inside to break down the adhesive from the tape/glue?
  8. Trojan1992
    First Name:
    Jon
    Car(s):
    Aug 2, 2019
    Newport Beach
    114
    Liked:
    156
    No, I tried thinking it was like other BMW's. You cannot access behind the fender liner. It has to be dropped.
  9. Supra Dupra
    Supra Dupra Well-Known Member
    Car(s):
    Supra MKV LE (Nocturnal Black)
    Jul 23, 2019
    United States
    361
    Liked:
    459
    Garage Profiles:
    I'm interested, but for the reasons others have stated above, does this come with instructions on how to install it?
    Also... would you be able to do one in matte black?
  10. 2k20HTownMKV
    First Name:
    Joe
    Car(s):
    Nov 2, 2019
    Houston
    64
    Liked:
    26
    Occupation:
    Technology Manager
    o what a pita. Might just wait to install it when I wrap my car in stealth or find some Vinyl in downshift blue to cover it.
  11. Trojan1992
    First Name:
    Jon
    Car(s):
    Aug 2, 2019
    Newport Beach
    114
    Liked:
    156
    It is worth it but not as simple as I had hoped. When I turned my wheel and removed the liner to get access I was amazed something is actually blocking the access to the reflector. Also, I used my friends lift as I did not want to try and fit my hands in there but ended up having to remove the bumper.
  12. 2k20HTownMKV
    First Name:
    Joe
    Car(s):
    Nov 2, 2019
    Houston
    64
    Liked:
    26
    Occupation:
    Technology Manager
    Looks much better without the reflector in orange. Curious if it’s the intake box that’s blocking. I will see if I can look at the diagrams and figure out what it is.
  13. Trojan1992
    First Name:
    Jon
    Car(s):
    Aug 2, 2019
    Newport Beach
    114
    Liked:
    156
    No, not the intake box, it is structural.
  14. 2k20HTownMKV
    First Name:
    Joe
    Car(s):
    Nov 2, 2019
    Houston
    64
    Liked:
    26
    Occupation:
    Technology Manager
    Found the install video from IND they even removed the bumper on the video. Looks like that adhesive is a PITA as you mentioned.
  15. Supra Man
    Supra Man Member
    First Name:
    Darren
    Car(s):
    Nismo 370z
    Nov 6, 2019
    Liked:
    does this fit the front and the back reflectors? or only the fronts?
Share This Page
Loading...
