BimmerLink Info & Error Memory?
shaloot
24 Supra 3.0p MT
Hey all,
So I captured these logs the day I picked up the new car, was surprised to see anything at all showing up here. Does anyone see anything here that is concerning, for a completely stock car? No actual check engine light appeared since I’ve taken delivery, and the only “alert” on the dash was the customizable going over X speed warning.
About 400 miles on the car total, but I’m just getting started using BC and BL. I am likely paranoid but don’t understand why anything at all is showing up here.
I’ll paste the list below hopefully it’s legible.
As a side question, does BimmerLink have the ability to capture actual logs of the parameters? I see all over the internet ways to do it with BM3 MHD etc.
Any input on the below codes would be extremely appreciated, thanks!
Info memory
Date: 8/22/24, 4:01 PM
01 Crash Safety Module
8 errors
803280: PDC cannot be activated
010012: Diagnosis master - info - fault memory blocked 803181: CTA active without activation
803298: HMI No valid parking board information received 803180: CTA cannot be activated
010020: Speed - signal incorrect
803282: RVC cannot be activated
803284: Park button reports errors
10 Central gateway module
13 errors
100100: Contact to FZM slave lost
100102: Invalid LocalSleepReadiness message received
100104: HW Weckgrund ZGW
100108: Functional subnet deactivation due to the startability limit 100109: Ignoring the functional subnet request due to the startability limit 100203: DM software error info warning
100204: Message monitoring: no system context signal
100406: FsCSM does not send a response to F60 or F70
100600: Flexray protocol startup time is too high
100601: Unexpected asynchronous state on Flexraybus
101008: Non-resolvable ambiguous routing - SG not in the SVT target table 801C2C: Unexpected_Reset
CD0601: Ethernet: CRC error
12 Digital Motor Electronics
3 errors
24000B: Timeout data EWS
030E1C: Power management: External charging detected
135501: Valvetronic: Warning threshold overload protection exceeded
29 Dynamic Stability Control (DSC)
1 error
D35D1F: D-OBD 3 - EPS - Communication error Diagnostic status message, group error
39 Virtual integration system
8 errors
030C67: INT-SVCHDL Input buffer overflow
03066F: QDM-ODO - degradation odometry
03065D: QDM-ZFM - Statistics proportion of linear travel range 0305AA: QDM-QEI - plausibility error
000002: FLEXRAY controller ACS error
03059B: QDM-Aaeps - set up by means of an index signal 030681: QDM-ZFF - limited control quality
0305A7: QDM-QEI - inputs not valid SBS
3F Active Sound Design
1 error
3F100D: Message (status convertible roof, 0x342): failure or signal invalid
56 Roof function center
3 errors
801A0E: NVM_E_INTEGRITY_FAILED 801A20: CAN_E_TIMEOUT
801A57: Anti-theft alarm system: deactivation of IRS and inclination sensor via customer function
60 Instrument panel
5 errors
B7F669: Combination: information error 1 B7F66A: Combination: information error 2 B7F668: COMBI: system time was reset B7F67C: Combined: CAN input buffer, data loss E106E1: SOME / IP error
61 Telematic Communication Box
1 error
610036: Flight mode due to failed network registration
63 Headunit High
2 errors
930010: MOST node: the DefaultRegistry is not up to date E1C601: Ethernet: CRC error
Error memory
Date: 8/22/24, 4:00 PM
1 error
CD0600: Ethernet: physical error (link off)
3 errors
139311: DOBD - IHKA-PR02 - Message (0x304, DME IBS_1): Failure. (OBD relevant for hybrid vehicles.)
030E08: Power management: Battery falls below upper startability limit
030E00: Power management: Transport monitoring, battery charge status deeply discharged
2C PMA
2 errors
803207: Sensor technology: noise detected 80334C: Multi-turn loss detected
30 Electromechanical power steering
1 error
D51408: Signal (vehicle speed, ID: V_VEH) invalid
40 Body Domain Controller
4 errors
804013: Supply voltage to terminal 30L1 is missing
804014: Supply voltage to terminal 30L2 is missing
8040D2: PWF status activation: Parking BN not ok
804130: DAYS: One or more blocked because game protection is active
5D Camera-based driver assist system
4 errors
800ABF: KAFAS camera: field of view temporarily disturbed
E0561B: 0xE0561B - signal error - 0x7530 - 0x0001 - BMW.CHASSIS - VehicleModel - signal invalid
E0561A: 0xE0561A - signal error - 0x7532 - 0x0001 - BMW.CHASSIS - SteeringAngle - signal invalid
E05614: 0xE05614 - signal error - 0x7531 - 0x0001 - BMW.CHASSIS - DrivingVector - signal invalid
60 Instrument panel
2 errors
E12C4D: DSC interface (lane slope, 0x163): signal invalid
B7F6EC: HUD: Incorrect image data received from the station wagon
1 error
03178A: SIF: General Mobile Network Errors
63 Headunit High
1 error
B7F8F6: HDCP: authentication failed
78 Integrated automatic heating / air conditioning system
1 error
E71455: Message (0x304, DME IBS_1): failure. (OBD relevant for hybrid vehicles.)
Branflakes123
Boston
2021 A91 Refraction Blue
Info logging is typically, well....informational only. Not necessarily an issue, just a notable event. The error logs are most likely not applicable to your car. For example: 803284: Park button reports errors. If it's a manual, this is irrelevant
shaloot
24 Supra 3.0p MT
Thanks, I get you on the info memory.
See anything I should be concerned about in the lower section, error memory?
