Clicking/Ticking noise coming from driver side.
BigTeamBattles
Harold
Posts
113
New Jersey
2020 Supra LE
My suspension, height, and wheel is all stock, the only time the wheels were taken off was at the dealer because I needed to get my tires changed. Recently I have noticed that on the driver side there is a ticking/clicking noise that almost sounds almost like pebbles rattling in the wheel well but there aren't any metallic sound. The ticking noise only occurs when I'm turning sharp right or cornering right at a certain amount of speed/g-force. The ticking noise doesn't occur when I'm not driving fast or if there isn't enough g-force applied at the turns. It also only occurs for right turns strangely.
Advertisement
APEXHunter
Joey
Posts
Bay Area
Just noticed this same thing on my car. It occurs in two situations:
  • On tight on ramps when turning right
  • When leaving my garage, clicks pretty loud at slow speed. Seems to go away soon after driving.
Did you figure out the cause?
BigTeamBattles
BigTeamBattles
Harold
Posts
113
New Jersey
2020 Supra LE
  • Thread starter
  • Thread Starter
  • #3
I went to the dealership so they can lift it and check it. So they did that and couldn't find anything wrong, they said everything is how it's supposed to be, lug is torqued fine, hubs are fine, the angles are fine, the suspension is fine, the arms are fine, so we went out for a test drive to replicate the sound and the guy heard it faintly. So far they can't find the issue and told me if the sound gets worse then come to them again. :/
APEXHunter
Joey
Posts
Bay Area
Well that's disappointing. Do you have the loud click in the garage? I noticed mine after my first track day with the car...
BigTeamBattles
BigTeamBattles
Harold
Posts
113
New Jersey
2020 Supra LE
  • Thread starter
  • Thread Starter
  • #5
Not in my garage, but I did notice some loud clicks when I was in my friend's driveway whenever i turned the steering wheel all the way
BigTeamBattles
BigTeamBattles
Harold
Posts
113
New Jersey
2020 Supra LE
  • Thread starter
  • Thread Starter
  • #7
Yea, but so far it hasn't hindered your driveability of the car right?
Because mine drives perfectly fine, it's just the ticking/clicking is annoying af
APEXHunter
Joey
Posts
Bay Area
Exactly, just annoying especially if you like driving with the windows down. But doesn't affect drivability
JDM_BMW
Posts
Arizona
2020 LE
I have the same noise.
To make you feel better Im in 5k hard canyon miles and I’ve been hearing that same noise the entire time with no big issues. I just keep checking lug bolt torque for piece of mind.
Z4LoL
Posts
San diego
2020 supra
Check your shock.. mine clicked until I replaced it with KWv3s. my stock shock had a bulge coming out of the rubber cover.. turns out the white plastic things under the dust cover had broken..
Advertisement
Advertisement
