Iconic_Supra
- Thread starter
- #1
So long story short I'm hoping for some help with my issues at the drag strip. I have an OTS 93/91 Octane Ecutek tune from a reputable vendor and a catless down pipe. Parts have been installed for around 3000 miles and I have 7500 miles on my 2020.
The issue is while shifting (in automatic mode) near 100 mph at wide open throttle I sometimes hit a rev limiter and it kills my speed. The last time this happened it caused check engine lights and limp mode. I didn't think to try to read any codes at that point. I believe this has only happened while using 93 octane. The last time I used the 93 from Casey's it did not have ethanol content % listed.
My only guess is an issue with fuel type or an issue with the OTS tune itself. If anyone has any answers I would greatly appreciate it.
Similar to issues @NitroYellowMKV @Sereph102889 are having in the thread below:
https://www.supramkv.com/threads/anyone-mess-around-with-60-130-times.10799/page-2#post-156886
EDIT: SOLUTION HAS BEEN FOUND. I ACCIDENTLY FILLED UP WITH E30 93 OCTANE ON MY PUMP GAS OTS TUNE AND THAT HAS BEEN CAUSING THESE ISSUES
