HKS IPERMAX MAX IV SP suspension kit is coming with limited launch edition
bigcat
Posts
105
Taiwan
2021 Supra 3.0 Premium
Official info from HKS:
  • The suspension kit made specially for the circuit driving. To celebrate the release at Tokyo Auto Salon offered in the limited color version.
  • HKS has done several circuit tests mainly at a racing course of Fuji International Speedway with Max Orido well known in Supra world (Mr. Supra).
    Vehicle equipped with HIPERMAX MAX IV SP, set a time 1.682 seconds quicker than the vehicle with the stock suspension.
  • Utilizes inverted damper for the front that goes into the knuckle securing the plenty of stroke even when vehicle is lowered.
    Uses slide on a pillow upper mount to adjust camber angle.
  • The original aluminum billet upper plate is used at the rear, it is as light-weight as possible but also improving the rigidity.
  • The straight wound springs are used at both front and rear. It helps to easily change the spring rate.
Note: Error canceller is required to be purchased separately after removing Electronic Modulated Suspension.
Hmmm, it's canceller needed just like KW solution.
Amfchang
AMF
Posts
62
Honolulu Hawaii
2020 Toyota Supra
Its crazy how the listed pricing is the same as KW's line with the DDC Plug and Play. Its 3300...
Advertisement
Advertisement
