Hubcentric ring for te37sl
Mrblack889
william
www.youtube.com
#A90 381 edition.. and r35
Hello all of you who use te37sl on the supra, did you guys use hubcentric ring ? I try use hubcentric ring 73/66 purhaces from speedindustry , the ring perfectly fit on the rims but the ring cant fit on my stock rotor ..
Likely because there are both 66.1 and 66.5 rings. The ring you have is probably a 66.1-to-73, while the Supra is 66.5.
These hubcentric rings are the ones I bought. In case you need it like right meow.
Okay, slightly bigger than the OEM Supra hub. Could be machine tolerances preventing the 66.6 from fitting on your 66.5 hub.
That said, the Supra is not a hub-centric car because the OEM setup doesn't use studs and lugnuts. Cars that use lug bolts are called lug-centric, and the centering of the wheel on the rotor/hub is done via the action of the lug bolts. So while it matters a lot to have the right PCD size on a hub-centric lugnut car, it doesn't matter much at all on a lug-centric lug bolt car.
NewGuy
Jose
21 Supra 3.0 Premium,18 X5 M
Funny, I had the same issue. Bought rings and didn't fit. I did a quick search on the forum and found some that fit. You need 66.1-to-73.1. I used those and had no issues.
kurumi
Northern Virginia
