I feel a shudder like vibration in rear??
1siksupra
Charleston sc
2020 downshift blue supra
Anyone ever feel a slight shudder / vibration in the rear of the car when in 2nd gear? Depending on throttle, I will feel it occasionally but drives fine and shifts fine driving it. Hard to explain but it's when I'm taking off or turning while driving not even full throttle just normal driving. Doesn't continue and will go away after I'm driving. Just weird. Any advice is greatly appreciated. Wonder if it could be the guibo?
underdonk
'21 Supra 3.0 Premium
I have this with the solid aluminum diff mounts and tranny mounts (to be expected). Does it worse in 2nd than most other gears. Assuming you haven't done any of that, bushing/mount going bad?
1siksupra
1siksupra
Charleston sc
I haven't done any upgrades. I did purchase slightly used and nothing was mentioned I guess I could look.
sams2k
sam
israel
have you driven the car only with the diff mounts?
how bad is the shudder / vibration?
bajanstefan
Stefan
3.0 Premium
It's your diff, I'm having this issue now. It seems like the final drive bearing is damaged and needs to be repaired, see if you can set it up sooner rather than later.
