MKV Toyota Supra Dimensions & Specs leaked in Best Car Magazine
Status
Not open for further replies.
johnny_10196
Ford
Scans from the March issue of Japan's Best Car magazine.
MKV
Wheelbase 2,470 mm (97.2 in)
Length 4380 mm (172.4 in)
Width 1855 mm (73 in)
Height 1,290 mm (50.8 in)
Curb weight 1,496 kg (3,298 lb)
Engine: 3.0L turbo inline-six with 335 hp and 332 lb-ft, plus 37 lb-ft overboot.
Transmission: 8 speed auto transmission.
Tires: 225/50/17 front, 255/45/17 rear
Compare to the old model:
MKIV
Wheelbase 2,550 mm (100.4 in)
Length 4,515 mm (177.8 in)
Width 1,811 mm (71.3 in)
Height 1,265 mm (49.8 in)
Curb weight 1,510 kg (3,329 lb) (non-turbo) 1,570 kg (3,461 lb) (turbo)
Differences
Wheelbase -80 mm (-3.2 in)
Length -135 mm (-5.4 in)
Width +44mm (+1.7 in)
Height +25 mm (+1 in)
Curb weight -74 kg (-163 lb)
Lexusisf
Vancouver, BC, Canada
2009 Lexus-ISF
That is exciting, dont know how accurate the info is but...Overall I like the pictures...looks like this could hiding under all that camo...rear diffuser seems alittle odd...weight is maybe heavier that projected? BretttS just posted same, plus 335hp 8 auto...
tfoxyr
matrix
suzuki swift sport
So basically this has a shorter wheelbase than the previous z4 roadster , underwhelming . I will be very dissapointed if these are true because they tried to make the car smaller than the competition to save weight but let's compare it to the corvette .
Base spec Corvette :
wheelbase 2710mm
length 4496mm
weight 1539 kg
power 460hp
Also corvette is coming with a manual with more power and has only 43 kg (95 lbs) difference. I simply do not get why they did not stick to the gen 4 supra formula . Ever since i heard it probably has no manual as an option and is not 2+2 i am becoming very sure this car is far from a GT car so not a supra successor in any sense.
HKz
Arizona
FRS
meh, probably fake otherwise the weight is quite disappointing. Doesn't really weigh less than a manual C7, has a much shorter wheelbase than one and power to weight even with the supposed 385 HP 6 cyl is down by a good amount....and I just saw that it also says 0-100 km = 3.8 secs, not sure how that math works especially with only 340 HP that the magazine reports..
Levi
France
Alfa Romeo
1500 kg? That is 300 kg more than GT86. Those extra 100 PS are lost by the 300 kg increase.
vb22
SC300
Maybe thats the weight of a full loaded or well equipped model? :dunno:
Modal170
NJ
toyota has debunked the first law of thermodynamics, they are gods.
gymratter
TX
Silver Spur & F-150
the specs aren't that far off from the original FTHS concept (minus the WB).
Wheelbase 104.33 in (2,650 mm)
Length 170.27 in (4,325 mm)
Width 73.23 in (1,860 mm)
Height 50.79 in (1,290 mm)
2JZ-No-Sh*t
NM
My feet
You still have the straight six. :p
soundman414
Marc
Chicago
BRZ
If this is close to true, this better be a car that you can walk out the door for well under $50k.
tfoxyr
matrix
suzuki swift sport
I present you the CLA 45 AMG
It has a 4 cylinder engine that made 360 hp in 2014 , now it makes 380 hp . Anyway though 4 or 6 cylinders , this z4 coup project is one of many compromises .
gymratter
TX
Silver Spur & F-150
for comparison the outgoing Z4 sDrive35is does 0-60 in 4.8 second with an extra 250lbs+.
Nati Beastcat
Cincinnati
1977 FJ40 Landcruiser - 1987 Buick Grand National
This Car is going to look good. The performance and no rear seats are looking like a no go for me. Hopefully we find out more next month!
Status
