Tettros
- First Name
- Tettros
- Joined
- Aug 19, 2022
- Threads
- 1
- Messages
- 10
- Reaction score
- 3
- Location
- California
- Car(s)
- 2022 3.0 premium Supra
- Thread starter
- #1
Only have 960 miles on the car.
Idk, that rattle is the concerning part. I can hear the injectors but sounds like more than that to me. I might just be deaf from all the open dump WOT pullsIt’s the injectors, welcome to BMW engines
I feel as if I’m going to come back with more problems. Had low coolant the other day, which I was shocked considering I have less than 1k miles, so I took it to the dealership to check if there was a potential leak. Now, the car has a rattling noise at idle as you can hear…check your oil? Any CELS? Definitely sounds questionable
Edit: with that many miles I’d take it back to the dealer
It’s definitely something more than the injectors. You can hear that rhythmic click of the injectors, but that deep rattle sound is something elseIdk, that rattle is the concerning part. I can hear the injectors but sounds like more than that to me. I might just be deaf from all the open dump WOT pulls
Honestly could have been. I do usually fill it up at this relatively cheaper gas station, but I always filled the car up with 91That is not injectors. Weird when a bad sound just goes away !? But good. Glad it did
maybe bad gas?
Do you have a Costco gas nearby? Their Costco is very cheap and Top Tier as wellHonestly could have been. I do usually fill it up at this relatively cheaper gas station, but I always filled the car up with 91
I do. However, every time I end up refilling, they are closed. Gotta change up the scheduleDo you have a Costco gas nearby? Their Costco is very cheap and Top Tier as well
That's what I use 100% of the time
I feel like it's worth it. I get 93 at Costco for almost the same price as regular from Shell. Thing is, it's basically the same gasI do. However, every time I end up refilling, they are closed. Gotta change up the schedule
