Remnant Performance OMEGA 65 Turbo Kit
_Sp1ral0ut
Jeff
SC
what power level should this turbo do?
its bigger then pure?
I think it is suppose to be comparable to a Garrett G30 990.
edit realized I said 990. Should have been G30 900 smh...
Bryan / Briana
Your moms bedsheets
Comparing Garret, Precision, or any other top-tier turbo manufacturer is also a little unfair. "Household" brands aren't exactly the same ballgame as Pure, CTS, Omega, etc.
I was going to say the same thing and also to head off the "CHINA!!!" thing at the pass...
Both Garrett and BorgWarner are manufactured in China as well. I believe Precision is still USA but ironically they are the most hit or miss quality wise of the three.
Which means... your stock turbo on your supra is a CHINA!!! turbo. ;)
Never said anything about China. Though BorgWarner makes turbos all over the world. 22 Countries. My uncle (well great uncle) works at a BorgWarner factory in Illinois where they produce turbos time to time.
Bryan / Briana
Your moms bedsheets
I know you didn't, but others have made that remark about the Remnant turbo implying it's a pile of crap because it's a CHINA!!! turbo.
stormgreysupra
stormgreysupra
Oliver
Budapest, Hungary
www.oemplusmods.com
2020 GR Supra A90 Edition
It's sort of like saying that, sure. It's the same CHRA I assume, which is great, however, CTS has a hit-or-miss track record with their CHRAs, the same with FP and Pure. Pure also has casting/machining issues. This is a whole new casting, obviously, because of the factory frame- a lot of R&D went into this design, and it's new. I'm not saying that Omega is bad or even might be bad, I'm saying I don't think there is a ton of data on this yet, in its current configuration.
I agree as far as castinf
Should make a lot more than Pure. The Omega 65 was rated for 840whp initially but since then they increased the turbine size which should allow for even more power.
Bryan / Briana
Your moms bedsheets
stormgreysupra
stormgreysupra
Oliver
Budapest, Hungary
www.oemplusmods.com
stormgreysupra
stormgreysupra
Oliver
Budapest, Hungary
www.oemplusmods.com
BoostAddict13
NE FL
2022 Supra 3.0 Premium w/DAP
Do you happen to have a compressor map available to see as well?
stormgreysupra
stormgreysupra
Oliver
Budapest, Hungary
www.oemplusmods.com
sams2k
sam
israel
  • Compressor Wheel (Inducer / Exducer) = 65.4mm / 81.0mm
  • Turbine Wheel (Inducer / Exducer) = 63.0mm / 58.0mm
according to this i dont believe it would make more then 850
the hot size is much smaller compare to presicion 6466
and the 6466 can do 950-1000 hp at best
  • compressor Wheel 2.535" (64.39mm) inducer / 3.410" (86.61mm) exducer.
  • Turbine Wheel 2.920" (74.17mm) inducer / 2.600" (66.00mm) exducer.
  • Compressor Cover Ported S (4.0" inlet/2.5" outlet)
thats the 6466 size
stormgreysupra
stormgreysupra
Oliver
Budapest, Hungary
www.oemplusmods.com
thats the 6466 size
It's not only about the size but more about the blade design and technology. The Omega 65's internal design is based on the Garret G30-900 turbo which is rated at around 900 crank. The sizing is however a noticeably larger. 850 to the wheels is a safe estimate but we will see during the tests.
