SupaSupra
- Thread starter
- #1
Hi everyone. Im having a rough time with the supra. Im requesting some assistance/ideas to get it running right.
Background:
Car has 3,500 miles. Mods include pure 800, catless DP, Viconti flex fuel kit and Ecutek. It has been running strong on E30 and below.
Two days ago I got new, sticky tires installed. Nothing else has changed. When I drove it home the car pulled hard as usual but backfired pretty bad. I was full throttle, E32 and went from 3 to 5th gear. It kept backfiring under full load. I data logged and sent to the tuner. He sent me a new file to try and said im running out of fuel, take down the ethanol content.
Took down the content to E27. The car does the same thing. It will consistently detonate.
The tuner informed me I'm just running out of fuel. It was suggested I need the port injection kit. Im very happy with my power level, id like to keep it at the power it is but running correctly.
I figured maybe I need new spark plugs. I changed them out to the NGK laser iridium 94201. It does not back fire (I think) but the car goes into limp mode after a good hard pull. The car threw a 130716 code-Error target camshaft control.
From the data log I can see the car is pulling timing really bad. also I can see the fuel pressure drops from around 34 pis down to 12s psi. can you guys please take a look and give me some advice. Should I have another tuner turn it down a bit?
Out of respect to the original tuner I choose not to disclose. I attached the excel file here. Thank you all kindly for taking the time to read.
Excel ecutek log
Background:
Excel ecutek log
