Old Spice
Well-known member
Vehicle(s)
X3 currently
Great look at underbody, skids and suspension of the 2025 4Runner TRD Pro and Trailhunter
Full credit to: https://www.theautopian.com/i-crawl...r-to-look-at-the-hardware-heres-what-i-found/
First thing’s first: This thing has a metal fuel-tank skidplate. This may not sound like a big deal, but it is, because none of the Tacomas I drove — not TRD Pro, not Trailhunter — came with metal fuel tank skids (it’s not clear if it’s optional).
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.11.53-AM-1024x434
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.12.12-AM-1024x492
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 11_1530494761209425_2305369721359771173_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 550_438184785325495_7699155086889147959_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 43_2470544746670106_4323141040656876929_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 120_795698912612747_7303003944222359318_n-1024x575
You can see that the exhaust is tucked up reasonably high, and up front, there’s a skid plate covering the transmission on the Trailhunter model:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.12.23-AM-1024x498
The aluminum transmission skidplate isn’t very thick, and felt quite wobbly. The fuel tank skidplate, too, felt very thin. But they were there, and so long as they don’t tear, and offer enough stiffness to reduce or eliminate loads on the transmission oil pan and blow-molded fuel tank, it’s fine.
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.20.05-AM-1024x508
You can see decent underbody protection from the chin all the way back behind the front subframe.
The TRD Pro, like the Tacoma TRD Pro, is less focused on rock crawling and more focused on high-speed desert running, so there’s not as much protection. There’s still a fuel tank skid plate and a skid plate at the very front (this time TRD-branded):
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.48.37-AM-1024x515
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 64_2481211905395812_7620106198158049644_n-1024x575
But there’s no skid plate below the transmission:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.48.53-AM-1024x578
It does still have a tiny steel skid plate bolted to the transfer case:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-9.54.04-AM
The 4Runner TRD Pro’s lack of a transmission skidplate reveals a sway bar that, when compared to the last-gen 4Runner, has moved from ahead of the front axle behind it (note: The TRD Pro and Trailhunter 4Runners have no rear sway bar). You can see the front sway bar, as well as the sway bar disconnect mechanism (standard on TRD Pro and Trailhunter and pointed out below):
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-9.22.59-AM-1024x563
Both trucks feature a double-wishbone independent front suspension and a five-link, coil sprung solid rear axle, with the TRD pro featuring red aluminum upper control arms and shock dust covers:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-6.16.49-AM-1024x574
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-6.16.41-AM-1024x586
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 796_937505221248445_1724890433759177566_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-6.17.07-AM-1024x586
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 8_446344417919377_4661763980674274261_n-1-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 336_1463350024389757_785075652640076801_n-1024x575
The Trailhunter has Old Man Emu dampers, and a gold/black/white color scheme on the control arms and shocks:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.52.29-AM-1024x582
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.52.40-AM-1024x589
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter Screen-Shot-2024-04-11-at-8.52.50-AM-1024x583
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 97_2130951350602379_2623278068565724123_n-1024x575
With a 32-degree approach angle and 24-degree departure angle, the 4Runner should be decent off-road, though it’ll probably drag its ass and belly every now and then. All four-wheel drive 4Runners will get low range, Active Traction Control (A-TRAC), and an automatic limited-slip differential (Auto LSD). Limited trims will offer a full-time transfer case with locking center diff, and the Trailhunter and TRD pro get only a part-time four-wheel drive system with way bar disconnect and a rear locker.
You may be wondering how this underbody compares to that of the Tacoma, and the answer is: They’re basically the same, with the only real variation happening at the center of the wheelbase (the fuel tanks, for example, look totally different). Here are some Tacoma TRD underbody shots:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 305_318478744586814_4106670127518595016_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 792_459578903086092_8427943486665753499_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 961_946980960058936_8987162801214699492_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 845_418412364166924_3666155395395387361_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 26_1066118037809917_3852560779351983176_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 103_782488746837781_2936915609591856971_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 91_1390530304936620_8290663784382983307_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 744_448249471107380_6326037135589359599_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 756_765997715627310_8431777150750868879_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 610_1631523404341870_993674017711547124_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 91_1139789347167933_4008572151691686419_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 54_1165589931459690_5918353210166419996_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 172_985030126639977_8614758807958962944_n-1024x576
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 92_1142107223650500_4817162389723127749_n-1024x576
And here are some Tacoma Trailhunter underbody photos:
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 076_954811676272509_5753859375636091056_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 721_796683865189286_8424024461601240736_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 70_1643447073150687_7482810652738099497_n-1024x575
2025 Toyota 4runner Skid plates, underbody protection, suspension of 2025 4Runner TRD Pro and Trailhunter 64_1377211236305993_4288280727859985504_n-1024x575
Anyway, that’s just my first look at the 4Runner’s underbody. The TRD Pro and Trahilhunter are just like the Tacoma TRD Pro and Trailhunter, except the middle bit is different and the 4Runner gets a metal skid plate for the fuel tank instead of just a plastic shield.
