This is the 2020 mid-engine Chevy Corvette
Discussion in 'General Automotive & Other Vehicle Talk' started by Supra93, Jan 8, 2015.
  1. Supra93
    Supra93 Moderator
    Moderator
    First Name:
    Tommy
    Car(s):
    Supra & RX7
    Jul 7, 2014
    TX
    1,123
    Liked:
    3,078
    Occupation:
    Chef
    Garage Profiles:
    Our exclusive mule sighting confirms that Chevrolet means mid-engine business.
    Behold, mid-engine Corvette fans: The car you’ve waited patiently for Chevrolet to build has finally evolved beyond titillating concepts to the engineering mule revealed here. An 82-second strike by our recon op resulted in 15 frames before security narcs dropped the curtain on this black test car—with its two occupants still inside.
    Don’t fret over the pointy-pickup camouflage; more attractive attire will follow. Instead take solace in a cabin hugging the front axle, ample space between the cockpit and the rear wheels for the hot parts, and this Corvette’s crouched and ready attitude.
    The nose clip is from Holden's Commodore SSV (with even wider flares), while the cabin module, roof, and exterior mirrors are hand-me-downs from today’s Stingray. A Holden SSV ute’s sheetmetal wraps door to door around the heinie. The wing keeps the tail planted during high-speed runs and what could be more practical than the bumper-mounted 2-by-10 for shoving this test sled back to the garage when it breaks down? Other items of note: The fuel-filler located on the driver’s-side B-pillar and the cooling intakes located along the rocker panels.
    Scaling the span between the axles using the wheels as guides (we’re estimating them at 19 inches in diameter) yields a projected wheelbase of 98.9 inches, some eight inches shorter than that of today’s Corvette. That blueprint upgrade comes from bumping the transmission from ahead of to behind the rear axle as God and Dr. Porsche intended. A tighter wheelbase quickens steering response and cinches up the turning circle. It goes without saying that at least 60 percent of this probable Corvette ZR1’s mass will be supported by the rear wheels, enhancing launch traction and balls-out braking. There are rumblings that the engine bay may eventually play host to a small, 3.5- to 4.0-liter V-8 with all the fixin’s—meaning no pushrods.
    Thus far GM has issued no denials discrediting our most recent (and highly detailed) mid-engine Corvette forecasts. While there’s no fresh intel regarding launch timing, the fact that experimental hardware has left the laboratory suggests that the C8 Zora sports car is on schedule to roll into showrooms in about 20 months as a 2017 model, at which point it will be sold alongside the front-engined Corvette. Place your orders now or find yourself stuck at the back of a long delivery line.
    http://www.caranddriver.com/news/exclusive-mid-engine-c8-chevrolet-corvette-first-photos-news
  2. Hal
    Hal Member
    Car(s):
    Honda s2000
    Jan 6, 2015
    Charlotte,NC
    Liked:
    GM just upped the ante. That's about the craziest test mule I've ever seen. Looks like an ute.
  3. OP
    Supra93
    Supra93 Moderator
    Moderator
    First Name:
    Tommy
    Car(s):
    Supra & RX7
    Jul 7, 2014
    TX
    1,123
    Liked:
    3,078
    Occupation:
    Chef
    Garage Profiles:
    Old article, but here goes.
  4. Hank Lee
    Hank Lee Active Member
    Car(s):
    IS-F Ultrasonic Blue (2010)
    Nov 9, 2014
    U.S.
    26
    Liked:
    Lutz spoke and GM smartly listened. Industry needs more mavericks like Lutz.
    All car enthusiasts should be required to read Car Guys vs. Bean Counters. Great book by Lutz on the constant behind the scenes struggle between the numbers crunchers and the real car guys at auto companies.
  5. FT1freddy
    FT1freddy Well-Known Member
    Car(s):
    FR-S
    Jan 13, 2014
    Powder Springs, GA
    72
    Liked:
    40
    Thought this was going to be vaporware but impressive to see Chevy actually pull it off. Extremely early for a mule tho? C7 only available starting last year.
  6. OP
    Supra93
    Supra93 Moderator
    Moderator
    First Name:
    Tommy
    Car(s):
    Supra & RX7
    Jul 7, 2014
    TX
    1,123
    Liked:
    3,078
    Occupation:
    Chef
    Garage Profiles:
    I think its happening.
    Just for clarification Mark Reuss is the executive VP at GM.
    A70TTR likes this.
  7. Craigy
    Craigy Well-Known Member
    Car(s):
    M3, Lexus GX
    Sep 30, 2014
    Louisiana
    562
    Liked:
    708
    Same old LSX V8 that's in every other Corvette and GM performance car, nothing special. And it's likely to suffer from the same ECU that pulls timing when you have too much fun.
    If the car can somehow reside within that mule or if it looks anything like that concept, it doesn't hold a candle to the new Ford GT. Not even close.
  8. OP
    Supra93
    Supra93 Moderator
    Moderator
    First Name:
    Tommy
    Car(s):
    Supra & RX7
    Jul 7, 2014
    TX
    1,123
    Liked:
    3,078
    Occupation:
    Chef
    Garage Profiles:
    Did GM Accidentally Give Us A Peek At The Mid-Engined Corvette?
    http://gmauthority.com/blog/2015/03/did-gm-accidentally-give-us-a-peek-at-the-mid-engined-corvette/
  9. OP
    Supra93
    Supra93 Moderator
    Moderator
    First Name:
    Tommy
    Car(s):
    Supra & RX7
    Jul 7, 2014
    TX
    1,123
    Liked:
    3,078
    Occupation:
    Chef
    Garage Profiles:
    All hail the Emperor! Chevy's Ferrari-fighter is almost here.
    http://www.autoblog.com/2016/09/12/2019-mid-engine-chevy-corvette-details/#slide-4056208
  10. Villa Jonny
    Villa Jonny Well-Known Member
    Car(s):
    Lexus [V8] RCF, Camry [V6] SE
    Jan 5, 2015
    Denver
    178
    Liked:
    294
    Occupation:
    Tech
    Garage Profiles:
    Might be Cadillacs Halo car? Well, rumors.. Lol
  11. Craigy
    Car(s):
    M3, Lexus GX
    Sep 30, 2014
    Louisiana
    562
    Liked:
    708
  12. black-supra
    black-supra Well-Known Member
    Car(s):
    Very Fast
    Jan 1, 2014
    212
    Liked:
    112
    Hopefully it will look better than the XLR.
  13. adprokid
    adprokid Well-Known Member
    Car(s):
    Dec 3, 2014
    Abu Dhabi
    63
    Liked:
    74
    I think the front engine Corvettes will still be offered along with the mid engine platform.
    Haros, vb22 and 2JZ-No-Sh*t like this.
  14. vb22
    vb22 Well-Known Member
    Car(s):
    SC300
    Jun 7, 2017
    1,139
    Liked:
    1,643
  15. Guff
    Guff Moderator
    Moderator
    Car(s):
    FR-S, BRZ, Supra, Mini Cooper
    Sep 8, 2016
    1,473
    Liked:
    6,600
    Garage Profiles:
    :bow:
    Chikane likes this.
Share This Page
Loading...
