Twisted Tuning A90/2020+ Toyota Supra B58 Stage 1/2 Modular Catless Downpipes
Twisted Tuning
www.twistedtuning.com
Our Stage 1 and Stage 2 Modular Catless downpipes 4.5″ full mandrel bent downpipe is the highest, smoothest flowing and highest performing on the market. Spool-up times are significantly improved. The gradual transition of our downpipe will allow exhaust to maintain its velocity without increasing back pressure. As with anything we release our aim is to over-engineer and outperform the competition.
We use thicker gauge SS materials than most other manufacturers which allows us to increase our product durability. We incorporate our custom downpipe support just like OEM for a much sturdier and OEM looking install which will help to also resist cracking or other fatigue.
POWER INCREASE: up to 25-35whp depending on car and environment and tune.
STAGE 1 DOWNPIPE NOTES:
Stage 1 one piece downpipe is designed to be used with stock diameter catback or stock diameter aftermarket catback exhaust systems.
STAGE 2 DOWNPIPE NOTES:
Our Stage 2 Catless downpipe features a two piece design that will allow consumers to run our downpipe with stock catback exhaust size up to 4" diameter catback exhaust without needing to buy and/or modify an entire new downpipe. We achieve this by allowing the lower section to be swapped out for a larger elbow to connect to the exhaust size of your choice up to 4" diameter. Two piece design is via SS V-band connections for great fit and finish and easy install and removal. The last Downpipe you need to buy!
FEATURES:
  • Significantly Lower Back Pressure Means the Potential for More Power
  • Exhaust Gas Can More Easily Flow Across the Turbine Wheel
  • Throaty Exhaust Note Under Wide Open Throttle
  • 304 Stainless Steel 4.5” Inlet Reduces to a 4" Flex Section, Maximizing Volume and Flow
  • Turbine Flange Offers a Smooth Transition from the Turbine Outlet
  • 3.15” (80mm) Outlet Allows You to Run Either Stock or Aftermarket Catback Systems
  • Fully Stainless Steel Downpipe
  • Complete Bolt-on Means No Cutting – Bolts to the Factory Location
CATLESS DOWNPIPE NOTE:
Use of Catless downpipes are for off-road use and racing applications only. Removal of the Cat will cause the ECU to flag a CEL for the Cat removal. This can be fixed via an ECU flash or O2 Simulator. Spacers have been proven not to work on these ECUs.
ORDER LINK:
https://twistedtuning.com/products/...catless-downpipes?_pos=4&_sid=a7065ddca&_ss=r
SOUND CLIPS:
Finally! Been waiting for this modular one since you guys mentioned it and video came out few months back!!
FYI, I do see the option in the dropdown for Stage 2, but unable to select it with Chrome&Firefox on Windows PC on your website.
On Android Chrome, in the dropdown Stage 2 is dimmed. (unable to select)
Twisted Tuning
Twisted Tuning
hey sorry for the late response. i left that greyed out for the moment until i build up a little stock of the stage 2. Should only be a couple days more.
Twisted Tuning
Twisted Tuning
Stage 2 downpipe is available for purchase now.
Twisted Tuning
Twisted Tuning
do you have any plans for a catted version?
One other person asked about the possibility of a catted version. Initially i had no interest in a catted version, mainly due to still needing to have a tune for the CEL with catted versions. For a catted version to be installed and not have a CEL you would need a high cell count, at that point why even bother, just keep the stock DP.
We are thinking about it though. If more people show a demand for a catted version, we could probably do it.
Twisted Tuning
Twisted Tuning
Just realized we didnt post any photos of our stage 2 modular downpipe......
We'll have some actual real post production photos shortly. Have not had time to link up woth our photography branch and shoot them.
Pictured on the left are some of our stage 1 downpipes and on the left are some of our stage 2 downpipes
nksupra
London, UK
Supra
Cool. I would definitely be interested. From my point of view (outside the US though), I am failing the annual check up regardless of catted or catless - changes are not allowed. I just want to maximize performance, while not dealing with the smell or the guilt. Also one of the tracks here requires the FIA minimum, which is 100 cells.
Edit: to clarify, my ideal would be catted at 100 cells. Assuming I will get a CEL and will get it tuned. In other words not looking for catted just because I want to pass inspection
Twisted Tuning
Twisted Tuning
Some updated photos, our downpipes have been selling like hotcakes and for good reason!
Twisted Tuning
Twisted Tuning
