Video: The Making of 1,000 Horsepower 2020 Supra Engine Parts
Discussion in 'B58 6-Cyl Engine, Exhaust, Drivetrain, Bolt-Ons' started by LS3Twins, Sep 10, 2019.
  1. LS3Twins
    LS3Twins Well-Known Member
    First Name:
    Ryan
    Car(s):
    2020 Supra 1998 E36M3 LS3 Twin Turbo
    Aug 22, 2019
    Charlotte
    273
    Liked:
    399
    Well it looks like Papadakis has now started making some parts for it and he is inching closer and closer to the end goal. I mentioned in the other thread that they may use an air to air intercooler and delete the OEM water to air system and that's the path they are taking. The are designing a new intake manifold since the B58 has an integrated W2A system. I can't wait to see the end result and maybe the "but it's a BMW engine" people will open their eyes a little bit. I am also coming from the perspective of owning high hp MK4's so this is not a biased opinion. Enjoy the video!
    supraboi, vb22, johnny_10196 and 10 others like this.
  2. AHP
    AHP Well-Known Member
    Car(s):
    '93 Supra TT Hardtop, '09 Corvette ZR1, '07 Corvette, '13 G37x, '10 Escalade ESV
    Nov 28, 2018
    CLT, NC
    178
    Liked:
    282
    Garage Profiles:
    :coffee:
    The '1000HP stock bottom end, no problem' crowd is awfully quiet...
    justbake likes this.
  3. OP
    LS3Twins
    First Name:
    Ryan
    Car(s):
    Aug 22, 2019
    Charlotte
    273
    Liked:
    399
    It will be interesting to see how this build comes out and I am in the process of trying to decide on a Pure 700 upgrade or just go with an aftermarket turbo upgrade. Yes the Pure is a direct bolt on but it's priced at $2400 which would be more than a brand new Garrett G30-770 or Borg Warner EFR 9280 at $2000. I could make that manifold in a couple of hours too.
  4. kona61
    kona61 Well-Known Member
    First Name:
    J
    Car(s):
    5G 4Runner, MK7 Golf, AZW LE Supra
    Mar 25, 2018
    San Bernardino-ish, CA
    848
    Liked:
    1,231
    Garage Profiles:
    Who said that?
    supraboi likes this.
  5. OP
    LS3Twins
    First Name:
    Ryan
    Car(s):
    Aug 22, 2019
    Charlotte
    273
    Liked:
    399
    I was wondering that too.
  6. supraboi
    supraboi Well-Known Member
    First Name:
    Vu
    Car(s):
    GS300
    Mar 6, 2018
    America
    1,064
    Liked:
    1,603
    I believe what Tada has said is that the car has been tested to hold up to 700hp or something along those lines.
  7. AHP
    Car(s):
    Nov 28, 2018
    CLT, NC
    178
    Liked:
    282
    Garage Profiles:
    I can specifically name at least one; the others I don't recall names, since much of that dialog was contained in threads that got deleted and/or heavily 'moderated' several months ago. I believe there is a (or at least was - as this person has a tendency to strategically delete posts) relatively recent comment to that effect in the first teardown video thread..
  8. kona61
    First Name:
    J
    Car(s):
    Mar 25, 2018
    848
    Liked:
    1,231
    Garage Profiles:
    Hm... I recall some saying 700-800 being possible, but I will have to see for myself.
    I agree with you. 1000hp is very unrealistic, at least for anything that would last more than 100 miles.
  9. MA617M
    MA617M Well-Known Member
    Car(s):
    lots
    Aug 27, 2017
    1,896
    Liked:
    4,502
    Occupation:
    Engineer
    1000hp on a stock bottom end JZ has it's lifespan measured in dyno runs. It's a misnomer.
    Anything above about 650-700whp and you'll need rods and main caps at the least - unless you don't plan on actually using that power.
    Dunc, Guff, RyanGT3RS and 1 other person like this.
  10. A70TTR
    A70TTR Well-Known Member
    Car(s):
    LX570, ST205 GT4, JZA70, JZA70 TT-R, Crown Athlete
    Sep 9, 2017
    Japan/EU/USA
    2,625
    Liked:
    9,433
    Occupation:
    Engineering liaison
    #10 Sep 13, 2019
    egh, 650-700whp if you're beating on it/tracking it (—I think this is more you Ryley), but I had a few friends at 8-900whp for a few years as highway cars (no issues).
    eventually they will let go, but they are pretty incredible that way.
    now, that said, I've heard that number is lessening due to newer turbos and e85. Larry from SP said they're bending stock rods now at around 750whp. crazy...
    in any case, always a good idea to build an engine before it blows a hole in the block, crankwalks, etc. I've never done billet mains on any of my JZs though (mine range from 6-800whp, both built) and would really only suggest that for those doing ~1kwhp+. Everything else though...
    F1 Silver Arrows and MA617M like this.
  11. kona61
    First Name:
    J
    Car(s):
    Mar 25, 2018
    848
    Liked:
    1,231
    Garage Profiles:
    Now is the bending today due to increased low end torque?
    F1 Silver Arrows likes this.
  12. A70TTR
    Car(s):
    Sep 9, 2017
    Japan/EU/USA
    2,625
    Liked:
    9,433
    Occupation:
    Engineering liaison
    Exactly. More torque, more instant, and sooner in the powerband.
    So, in that light, the B58 may already be every bit as stout in stock form even if it starts having issues around that same level as it makes power in a similar fashion.
    The older JZ setups had less of an issue due to the difference in power delivery.
  13. AHP
    Car(s):
    Nov 28, 2018
    CLT, NC
    178
    Liked:
    282
    Garage Profiles:
    Assuming a good ECU, tune and fuel the general guideline for a happy stock bottom end 2J is keeping the revs at 8000RPM max and <700WTQ, regardless of the WHP it puts out. Ethanol fuel and turbo tech has resulted in a lot of windowed blocks these days due to the massive difference in TQ delivery down low.
    Mk5nut, MA617M and A70TTR like this.
  14. A70TTR
    Car(s):
    Sep 9, 2017
    Japan/EU/USA
    2,625
    Liked:
    9,433
    Occupation:
    Engineering liaison
    #14 Sep 13, 2019
    yeah, driveline stuff breaking is always a function of tq, but that said for a long time the relationship between whp and tq was generally a stable one (hence I forget to clarify, and I see a lot of others doing the same). these days though, perhaps not so much especially given where it's coming on in the powerband.
    that said, that wtq figure sounds about right.
    MA617M likes this.
  15. MA617M
    Car(s):
    lots
    Aug 27, 2017
    1,896
    Liked:
    4,502
    Occupation:
    Engineer
    Yes, that's probably the biggest factor I'm seeing these days - newer turbo tech and E85. I'm a little worried about my rods with 23psi at 3400rpm haha, and I haven't even put E85 in yet.
    The other trick to keeping them happy is ramp the boost and timing, so it's quite soft around peak torque but then cranks in at higher rpm. You keep the bottom end safe, but you get the power figure.... but that shape of torque/power curve isn't for me - but each to their own.
    LS3Twins and A70TTR like this.
Share This Page
Loading...
