Toyotawild
- First Name
- Zach
- Joined
- Apr 27, 2019
- Posts
- 379
- Reaction score
- 258
- Location
- Richland wa
- Car(s)
- 07 Toyota Tundra supercharged, 03 Acura cls-6
- Thread starter
- #1
What o2 extender works to trick the ecu for no cel. Thanks
I've looked into it and I doubt any will work reliably. The O2 sensors are too sensitive in these cars and it will likely trigger a CEL if you get on it.What o2 extender works to trick the ecu for no cel. Thanks
What do we have for options then. Jb4 support the cel delete yet. Or is bm3 out only optionI've looked into it and I doubt any will work reliably. The O2 sensors are too sensitive in these cars and it will likely trigger a CEL if you get on it.
Oh yea? I wonder if their module mitigates the CELNot sure what spacer setup Titan Motorsports uses but no cel lights with piggyback setup
It is a fabspeed precious metal extender. Pretty pricey but if it works its worth it. Wish jb4 could take care of it.Oh yea? I wonder if their module mitigates the CEL
Yea, I think it will work most of the time, but a CEL may trigger under hard driving.It is a fabspeed precious metal extender. Pretty pricey but if it works its worth it. Wish jb4 could take care of it.
That's super neat, never heard of it but I like it. The only issue is I don't know if it will fit, it's pretty tight down there.http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
These things rock - they are basically mini cats (minus the drawbacks) and you will not get a CEL with it installed.
I've had these installed on several Lambo's I've owned with aftermarket exhausts. No more CEL.
Yes, stock tune with Titan downpipeKeen to hear how you go. Are you running a decat dump on the factory tune so far?
