When will you do your first oil change?
Ryanthetemp
Ryan
Fort Walton Beach, FL
Past: E28 M5, E24 M6, E30 325is
normally the first oil change is 5K and then 10K interval on new Toyotas. The manual says 7.2K interval on the Supra, does that mean the first oil change is 3.6K? I haven’t seen anything discussing this...
s219
Doc
Virginia USA
I suspect it uses condition-based-service (CBS) based on the BMW iDrive system. Hunt through the menus, look under Vehicle > Vehicle Status > Service Required (or similar if it was tweaked on the Supra). That will give you an estimate of when the next service is required and should update based on the driving. BMW generally calls for oil changes between 12,000-15,000 miles, or 1 year, whichever comes first. Toyota may have changed the mile limits, but probably still uses 1 year. If you put low mileage on your Supra, as I suspect many folks will since it's a second/third car for them, then you may fall into the 1 year intervals.
POS VETT
Tom
Columbus, OH, USA
'20 Tacoma SR 4X4 V6, '20 Terrain SLE, '11 370Z Sport, '9 Eclipse GS, 8 Corvette Z06
It will be within the first 1k miles for me just like any other car I have bought new. Likely it will be between 500 and 800 mile marks.
mkhank7865
2020 Supra LE, Jaguar F Pace, BMW 435 GranCoupe
service manager said 10k miles is what the manual said but he recommended doing the first at 5k then 10k then every 10k after that
084runnerltd
Jake
ND
This weekend for me <3,000 miles.
LS3Twins
Ryan
Charlotte
2021 Supra 1998 E36 M3 LS3 Twin Turbo
Toyota(BMW) recommends 10,000 but I did it at 3,000 miles.
084runnerltd
Jake
ND
Did mine today, posted a walk-through in the DIY section. (3,200miles)
Bruins71
Tony
ontario,Canada
Supra MKV, Highlander,Mitsubishi Lancer Ralliart
I now have 4k and I will be putting it in climate control storage on October 26 :(with the oil that came in the car.
Around April 9 I will pull the car out :) and get its first oil change . This will last the 2020 driving season as
I expect to do about 8k-10k.
Phantom Grey Supra
Christopher
2019’ Yamaha R1m —2020 F450—2021 Supra 3.0 —1999 silverado 4x4–1997 Husqvarna CR250– 2012 VW Jetta GLI TDI conversion
Just did my first oil change at 900 miles . There was sparkly silver glitter in the filter (normal). It was about 5 little specks of metal on each fold in the filter.
Frosty
IL
2020 Toyota Supra, 2016 Ford F150, 1993 Ford Mustang GT
I’m going to wait until about 1,200 miles to do the first oil change. Switching to a slightly thicker oil (5w-30) and change it every 4-5K miles thereafter.
Bflood
Columbus OH
3.0 Premium
That's exactly what I'll be doing. Already did the first change and have the second kit sitting on the shelf.. also picked up a transmission service too and will be doing that at 25k then every 40k thereafter.
Service kits I'm using (if interested):
OIL - https://www.ecstuning.com/b-assembled-by-ecs-parts/oil-change-kit/hu6022zkt/
Transmission - https://www.ecstuning.com/b-assembled-by-ecs-parts/trans-service-kit/24118612901kt/
