Thanks. only probably going 285 wide on the front if I can on stock suspensionCheck out the thread I linked. These guys are running 11ā square setups probably will be relevant information.
Seems negative camber is a must for the fronts when that wide, but 315 is the widest recommended tire from Apex.
I donāt know if this is helpful but Iāve got 275s on stock suspension, stock wheel on the front. It rubs very gently when itās loaded heavily in a hairpin or corner. It also rubs at full steering lock. I think going wider I would need a spacer, but probably not on stock wheels at that point.Thanks. only probably going 285 wide on the front if I can on stock suspension
