FLY1 Motorsports Carbon Fibre Side Skirts
reNeglect
Ben
Alberta
2020 Toyota GR Supra, 2017 BMW X5
Decided to go in another direction.
Never installed, just test fitted. Some adjustment was made (eg. trimming in the excess fibreglass to achieve good fitment.)
Asking 900 USD Shipped
Located in Calgary, Alberta, Canada
kingkai23
Kai
Nj
2021 a91 2021 gti 2014 sti
Where u located
jorligan
Tim
michigan
Ferrari 458, McLaren 650S, Porsche GT3, Alfa 4C, Ford Raptor, Porsche Macan, 21 Supra Turbo
Is that a scratch? How is the fitment after trimming? How does it mount?
reNeglect
reNeglect
Ben
Alberta
Scratch from a knife when unpacking, should be able to repair with clear coat or some light sanding and PPF.
fit is good after trimming some of the excess fiberglass in the bottom mounting tabs.
should be mounting by 2 screws/bolts and double sided tape. Basically you keep your oem one on, and this kinda clips on to it. Then double side tape along the entire side. self taping screw or bolt/nut or rivet nut + bolt in front bottom mounting tab. Then last a self taping screw on the rear into ur oem skirts.
hope that makes senses, there’s no instructions online or via fly1, had to test fit and see where you can add fasteners
kingkai23
Kai
Nj
$700? If so pm me im in nj
