Benjilis
Correct. But it’s a cheaper shortcut right now than getting a o2 sensor thst won’t work.As I understand back-end flash still needs the Ecu to be flashed.
Slightly warranty issue. Slightly because the tuners are asking $800 for a custom tune on top of the ecutek and they will charge for mapping later on.Unless you’re worried about warranty I would go straight to Ecutek, especially if you’re flashing the Ecu. Doesn’t make sense to run a piggyback and then flash an Ecu. Upgrade the turbo and you can just have a tuner send another map.
would rather put my money into other parts of the car and my life.
Im content with the jb4 and MHD back end flash results for now
