Delivery Delay Due to Fuel Pump
Msh21
Rum
DMV
2020 3.0 Supra
Hi all,
I wanted to see if anyone else had this issue with their 2020 3.0 Supra.
I recently purchased the car, used with under 7k miles, and the delivery got delayed because:
1) Dealer said they couldn't get the car to start up again after getting the inspection done
2) They tried jumpstarting the battery but that did not work
3) Waited a day and it started up but not as smoothly as it should have
4 Then they detected that the fuel pump is messed up...
They informed me that they will be installing a new battery because the old one was a little low on charge and they'll also be installing a new fuel pump because they noticed the car jerking and not starting up properly.
Any idea why the fuel pump might have gone bad for a 2020 with under 7k miles?
Has this happened with any first owners who have been using the proper gasoline and no mods?
Thanks!
Cptnslo
Colton
2020 MKV 3.0 Supra
At least they’re replacing it!
Msh21
Rum
DMV
2020 3.0 Supra
Yup! I am glad everything is covered under the warranties but just a little frustrated that it keeps getting delayed because they couldn't properly diagnose the main issue.
Probably highly tuned.... Possibly had low grade fuel, wrong ethanol mix. ?
Any hints under hood for mods?
Check other battery threads. There's a procedure for resetting battery..
Msh21
Rum
DMV
2020 3.0 Supra
So from what I know, the car was all stock previously. My guess was wrong fuel/contamination as well.
I'm just curious if any first owners had issues with their fuel pump without any mods and such.
