Lordhowe
- First Name
- HG
- Joined
- Jun 7, 2021
- Threads
- 12
- Messages
- 61
- Reaction score
- 31
- Location
- Northern VA
- Car(s)
- Toyota Yaris
- Thread starter
- #1
I'm running a set of 18x10 APEX ET30 squared wrapped in 275/40-18 Eagle F1 Supercar 3's + Camber plates to get about -2.3 of camber up front. Since the Goodyear runs a bit wider than similar-sized tires, I've noticed a slight rubbing between the spring perch and the tire.
After reading APEX tech article, I'm thinking about just running a 5mm spacer. The best option that I found so far is the Future Classic spacer kit.
I've never run spacers on the track before and while it's only 5mm, I wanted to get some input from folks that track their cars. I mostly care about safety and will be leaving the spacer there when I swap back to the factory wheel/tire setup.
Thanks for the input
