- Thread starter
- #1
The Toyota Supra MKV also known as the A90 | A91 has been a huge hit in the tuner car world. These cars have already been boosted up to almost as much power as their predecessor, the Supra MKIV. With more power, weak points start to appear in the engine and accessories. One of the most common failures of tuned B58 3.0T engines is the factory chargepipes cracking or popping off. This failure of the plastic pipes can be due to increase boost pressure with how easy it is to tune these. VR Performance has the perfect performance upgraded that is functional and sexy to look at under the hood. The titanium chargepipe and j-pipe kit will solve these issue while improving efficiency.
The VR Performance chargepipe kit is made up of the Hot Side and Cold Side sections. The hot side includes 1 titanium pipe that is a direct bolt-on in place of the factory part. These new pipes help to delivery charge air efficiently to the engine. The increased volume allows for higher boost without the possibility of cracking or popping off. Precision fitment of the replacement parts is done using stunning titanium pipe cuts from 3D scanning of the factory pieces.
The cold side "J-pipe" is also titanium featuring a precision mounted PCV connection which prevents check engine lights and limp mode. We have also incorporated a pre-capped 1/8" NPT bung into each pipe for those that may want to run water/meth injection.
Each kit Includes heavy duty couplers, hose clamps, and all hardware required for the installation.
Features:
Functional and stunning titanium construction
Lightweight at 3.1lbs
Precision fitment and PCV location
OEM replacement
Easy installation thanks to provided hardware
Can withstand high boost pressure
No check engine light
Everything required for installation included
VR-A90-CP-TI-8__22366.1644012071.jpgVR-A90-CP-TI-7.jpgVR-A90-CP-TI-9.jpgVR-A90-CP-TI-10.jpgVR-A90-CP-TI-11.jpgVR-A90-CP-TI-13.jpgVR-A90-CP-TI-14.jpgVR-A90-CP-TI-15.jpgVR-A90-CP-TI-6.jpgVR-A90-CP-TI-12.jpg
