Sold: FS: Front and Rear Brembo BBK by SW
DarkZupra
Matt
Orlando, FL
2021 Supra 3.0
Signature Werks Brembo BBK for the A90 - $2900 $2600
If you are unfamiliar with this kit, it uses OEM GM Brembo calipers plus an OEM Tesla Brembo E-Brake caliper, custom mounts, and custom rotors to enable a full BBK on the A90 without losing the E-Brake.
Front Specs:
6 Piston Brembo Calipers
380mm x 36mm 2 piece rotors
Custom mounting brackets
Braided Hoses
Rear Specs:
4 Piston Brembo Calipers
380mm x 28mm 2 piece rotors
1 Piston Brembo E-Brake Caliper
Braided hoses
Ill be including 2 sets of pads that both have plenty of life left:
Hawk HPS 5.0
Dixcel ES
Landed cost for this setup new is about $4300, with each set of pads costing around $500, totaling around $5300. Feel free to ask any questions.
One note - I would _not_ suggest this kit for anyone running either OEM dampers or any aftermarket damper that keeps the DDC/EDC connector in the same location on the rear, as the E-Brake motors come VERY close to touching them.
