Sold: FS: iSweep titanium stud kit heat treated pvd
EdgeOfSanity
Houston
2026 GR Supra, 2023 Audi S4
I have an almost new iSweep Ti stud kit for sale which is in the heat treated pvd color. The studs were bolted onto the car then immediately removed due to my BCF wheels lug holes not having been drilled wide enough for them. The lug holes on my BCF are 14mm diameter, you need 15mm to run these. I've gone a different direction since then and need to let these go. There are some marks in the coating from installation and removal on all of these which is going to happen even if you buy new. One set of 5 had a wheel fitted and have some more marks in the coating from the super tight fit, I highlighted the worst of it in the pics.
Asking $400 shipped to the lower 48. Set retails for $750.
Worst example of the 5 that had a wheel bolted to them.
Timmy_Jones
Tim
NH
23’ 3.0 Base
Do these work with OEM wheels? Apex wheels? Not familiar with what a standard lug width is.
EdgeOfSanity
EdgeOfSanity
Houston
Since I have both the OEM wheels and happen to have just bought a set of apex VS5RS for my track set I went and measured the lug holes. Both measure 15.5mm so these will work with them.
