Alternator not charging after engine rebuild
doowatchyalike
nick
maryland
supra
I just had my engine rebuilt and the car starts and runs just fine. The issue is the car isn't recieving a charge from the alternator. Initially I thought maybe the coding for the battery was lost because the battery was unplugged for so long, so I replaced the battery, coded it with BimmerCode, and registered it with BimmerLink. The problem is still there. I can drive the car fine. Using a monitor, I can see the voltage slowly go down as I run the car. Searching I couldn't find any information on this. Any guidance is appreciated!
Vertex
Vertex
Midwest
2022 3.0 Supra
I'd make sure all hardware and connectors are secured for the alternator. That would be my first go to or grab a multimeter and see if the alternator is doing anything with the car running for whatever amount of time you can
