Better Airflow? ARMASPEED Carbon Fiber Cold Air Intake
ARMASPEED
Ben
Taiwan
BMW G20
Supra A90 MK5 3.0 Carbon Fiber Cold Air Intake:
Premium Material:
Constructed with fine carbon fiber for durability and aesthetic appeal.
Efficient Airflow Design:
Specially developed to offer a direct and efficient airflow path to the turbo.
Enhances overall efficiency and performance of your Supra.
Increased Horsepower:
Engineered to generate additional horsepower for a noticeable increase in performance.
Distinctive Turbo Sounds:
Delivers a range of turbo noises which were muted with the OEM intake.
Experience the turbo’s response
Visual Appeal:
Designed not only for performance but also to visually complement your vehicle’s engine bay.
Easy Installation:
Direct bolt-on design ensures a hassle-free installation process without the need for modifications.
Perfect fitment for B58 engines.
No ECU Remapping Required:
Installation does not require remapping of the ECU/DME, making the process smoother and simpler for the user.
Click to get yours!
TwoPointYo
So Cal
2021 2.0 GR Supra
Hey can you explain why we lose horsepower on a dyno compared to oem intake? You lose a lot of top end power when running armaspeed cai.
Pizza
Mitch
Michigan, USA
I'm not Armaspeed but the answer is pretty cut and dry overall. If you lost power on a back to back dyno run after installing an intake:
1. The new intake doesn't have as much airflow as the previous one
2.The new intake doesn't keep the air as cool as the previous one
So the Armaspeed intake either has one or both of those present compared to stock.
