Hub Assembly Removal and Installation
ShinDohyun
Dohyun
Maryland
2022 GR Supra 3.0 Premium
Does anyone have experience removing the hub assembly from the knuckle?
I removed that four T60 bolts From behind the hub assembly (which has red thread locker).
Any tips or tricks are greatly appreciated.
nibble
NJ
BMW, Honda, Toyota
From my experience from M240i, once you have removed everything else from the hub, - like wheels, rotor, wire, those 4 bolts & etc. - it should come off although it may need some persuasion. also make sure you have something to catch it. it is on a bit heavy side so if it falls on your stomach, that would not be a pleasant experience.
