Kyostar 4" Intake Review vs MST V2
30MilesOffshore
30MilesOffshore
Charlotte, NC
Goko
Goko
Arizona
2024 Supra 3.0 Premium MT
Finally got around to installing the Kyostar intake and fitment is great. I did however, had to bore out the nipple that accepts the breather… otherwise no issues. I made a carbon fiber cover. Badge equates to -6hp, +11dB ?
I’m running into the same issue where the breather connect is not wide enough. What drill size did you use? Thanks
Benzito
AZ
Supra
If you don't want to use a large drill to bore it out, you can also take a soft grinding wheel / bench grinder and take off some of the plastic material from the breather hose connector. Just trial and error to take off enough to get a snug push-in fit. No need for any sort of clasp.
