Max tire size on OEM Rear square set up
Supraslowww
Gian
Austin, TX
2021 Supra MKV 3.0 Premium
Anyone know max tire size I'd be able to run on a set of square OEM Rear Wheels with HKS adjustable springs, 13mm spacers up front, and 15mm spacers in the rear? Thinking I'll switch over to Nitto 555R2 over the Michelin PSS, right now have the stock tire size of 275/35/19 on all four corners, seeing if anyone knows if I could go wider than that with no issues?
The 500 threads asking the same thing before you did might have the answer.
Supraslowww
Supraslowww
Gian
Austin, TX
Could you link some? All the threads I came across talked about the regular OEM set up or if they're running square setup it's a different set of wheels that are not the same size as OEM.
