Nocturnal detailing products and water spots
yfeghhi
Deep in the Heart of, Texas
www.instagram.com
2020 Supra MKV
What is everyone using on their Nocturnal A90s to wash and protect? What about for water spots?? We have a lot of hard water here and I cant seem to get water spots off. Right now I have been using a couple of chemical guys products but whats the best or what does everyone recommend for black vehicles and also for water spots.
jtsang25
Have you ceramic coated your car? I use chemical guys and carpro products
JasonO
Lake Charles, LA
Supra LE
Get a water filter on your hose. It doesn’t eliminate it, but it helps. A good ceramic coat will help. Any spots can be wiped off with little effort.
AustinGRSupra
Austin, TX
2020 GR Supra
I get great results with:
one-two gallons distilled water
one-two ounces of no rinse wash&shine
once over with the super absorbent towel
No spots, no wasted water/runoff.
HaiFrends
Brevard County
2020 3.0 GR Supra Nocturnal Black
Been using any ph neutral carwash soap and brake buster. On light washes ill do ONR. It has a cheaper DIY ceramic coat on it that i put on the car early in its paint life. armor shield? i dont remember the name. water beads pretty well
Waferz
Michael
Louisiana
About 3-4 washes in my car got drilled with water spots..... not even trying to remove them until I build a garage. The Finish on these cars is really soft and spots easily. If your car sits outside and the rainwater causes water spots, ceramic coating will be a waste of money as it will water spot just like the paint.
yfeghhi
yfeghhi
www.instagram.com
2020 Supra MKV
I've been using chemical guys products. Still gets water spots but not as noticeable from a distance. Probably have to reapply ceramic coating at some point but the wash and waxes work well enough.
