AMS Performance Toyota GR Supra - 20th Anniversary Limited Edition Parts
Extreme Power House
x-ph.com
18 BMW M4, 13 Mustang GT
AMS Performance Toyota GR Supra Chopped Carbon Fiber Air Intake – 20th Anniversary Limited Edition
With 20 years of documented research and development in the forced induction field, AMS Performance has proven itself as the powerhouse in the automotive aftermarket. Our award-winning performance systems are what all others are measured by. In celebration of our 20th year here at AMS Performance, we are pleased to announce the 20th Anniversary Limited Edition version of the GR Supra intake, in a special chopped carbon construction giving it an exclusive forged carbon look. These are expected to only be available for a limited time in 2021, so act fast!
Our AMS Performance Toyota GR Supra Chopped Carbon Fiber Air Intake kit was designed to draw a higher volume of cold air into the stock turbocharger. With this intake installed, the factory plastic filter box and plastic intake tube are replaced with our motorsport grade matte carbon fiber components and dry media air filter. The MKV Supra Carbon Fiber Air Intake Kit is a vast improvement over the stock intake system and in our extensive SnailWorks© Engineering Team R&D testing has shown a massive 25% increase in airflow efficiency!
25% Reduction in Airflow Restriction (Pressure Drop)
Draws a Higher Volume of Cold Air
Enclosed Intake Completely Seals Out Hot Engine Bay Air
Motorsports Grade, Hand-Laid Carbon Fiber
Durable Billet Aluminum Mounting Hardware
No Yellowing or Fading Over Time
Even Distribution of Cold Air Across Filter
Dry Media Filter means Easy Cleaning and NO Oil
The Power of Focused Engineering
AMS Performance is an engineering company first. We have built our decades-long reputation as a leading motorsports aftermarket component manufacturer by creating the highest performing parts through a focused engineering approach to design. This engineering process is what makes the MKV Supra Carbon Fiber Air Intake the best-designed intake system on the market The largest component of the MKV Supra Carbon Fiber Intake is the sealed cold air intake box. Our SnailWorks© Engineering Team knows that heat is the biggest power-robbing factor that plagues other inferior intake system designs. That is why they designed the airbox to seal out blistering engine bay temperatures. They then took advantage of the Supra’s existing intake ducting that funnels fresh air into the intake box by designing an airbox opening that matches perfectly to the air duct. Our engineers did not stop there.
When they focused on the other system components they found even more places to improve the design. The intake piping has been increased to 90mm for increased airflow, and to provide future compatibility with larger aftermarket turbo compressor cover inlets. This is a massive 26.5% increase in cross sectional area over the factory system, which has flow-reducing corrugations and reduces to 65mm at the compressor cover inlet. Whether you plan on leaving the turbo stock or going with an aftermarket unit, this intake system has you covered.
The Difference is in the Details
You can expect an easy install without cutting, trimming, or taking off any additional components. It can be installed with basic hand tools in minutes! Couple that with a purpose-built, reusable synthetic high-flow dry media filter, you’ll no longer have to purchase cheap factory paper filters down the road. The “Dry Media” filter means just that, no more messy oiling of your filter. Just one more reason why our intake is the best option on the market. The washable MKV Supra synthetic media filter was designed and manufactured specifically to fit this high-performance automotive application, and the filter size and configuration was fine-tuned to ensure that it will still provide all the necessary air for any MKV Supra, including upgraded turbo cars, without any substantial restriction or compromise in filter efficiency.
The new large AMS airbox was specifically designed to distribute airflow evenly over the entire circumference of the intake filter by allowing air to swirl around it. This means greater distribution of cold airflow across the filter resulting in lower pressure drop and a longer filter life between cleanings. The AMS Performance MKV Supra Carbon Fiber Intake Kit is engineered to deliver a 25% reduction in pressure drop which leads to better efficiency and more power. Because the Supra uses a torque-based ECU tuning strategy, our SnailWorks© Engineering Team has found that horsepower is not significantly changed with any aftermarket engine components unless proper ECU calibration is made to take advantage of the new hardware components. Our team even went so far as to add a much larger turbocharger to our test Supra and found 0 hp gains without tuning. Do not be fooled by competitor’s claims of horsepower gains without ECU calibration! Our Engineers designed the fully enclosed dry air filter to draw in a larger volume of air into its hand-laid carbon fiber constructed cold air box.
Kit Includes
Limited Edition Chopped Carbon Fiber Sealed Airbox
Limited Edition Chopped Carbon Fiber Intake Tube
Rubber Grommet Airbox Seal
Dry Media Filter
Billet Aluminum Brackets and Stanchions
All Necessary Mounting Hardware
Online Installation Instructions
Applications
2020 Toyota GR Supra – w/ B58 3.0L Turbo Engine
2021 Toyota GR Supra – w/ B58H 3.0L Turbo Engine (*Does not fit with factory strut tower bracing unless additional spacers are used*)
Product Notes
The filter uses specially designed dry media that allows performance and efficiency to be restored to near new each time by simply using compressed air (30-40 psi) from the inside out, making frequent washing unnecessary in order to restore filter performance. For a deep cleaning from extreme environments, a biodegradable cleaner such as Simple Green or other mild shop degreasers can be used. Simply place the filter in a solution or spray the cleaner on the filter. Allow the solution to loosen the particulate and then rinse thoroughly. Shake the filter or use compressed air from the inside outward to remove residual water and allow 24 hours to dry.
*Does not fit with strut tower bracing unless additional spacers are used*
As these motorsports grade, carbon fiber parts are hand-laid, slight imperfections or weave pattern variances can be expected.
AMS Performance Toyota GR Supra Chopped Carbon Fiber ECU Cover – 20th Anniversary Limited Edition
Kit Includes
Limited Edition Chopped Carbon Fiber ECU Cover
Applications
Product Notes
AMS Performance Toyota GR Supra Chopped Carbon Fiber Engine Cover – 20th Anniversary Limited Edition
Lightweight and aesthetically appealing, the AMS Performance Toyota GR Supra Carbon Fiber Engine Cover is engineered to give your B58 engine a high-performance look while shedding over half of the weight. The engine cover has been massaged into a sleeker design from the factory piece. 100% real carbon fiber construction saves valuable weight while holding up to the heat in high performance engine bays.
Applications
bryanole27
North Carolina
2020 Supra GR
I have all of these parts in the non-anniversary version, but I love the look of the chopped carbon and would have bought these instead. No way I'm doing them all again though.
Deighvid
Deighvid
2021 3.0 Supra Premium
Links? Are these available still or were they limited and sold out?
Extreme Power House
Extreme Power House
x-ph.com
limited quantity, they ran one batch and as far as I'm aware, they will not be running another one.
Still in stock
www.x-ph.com
