How to rock work meister
Keemaca
Mario
2024 Supra
I’m most likely, if I did build a set of S1’s, would do 19x9.5 +24 R Disk fronts, with 265/35 tires and 19x11 +38 L Disk rears, with 305/30 tires.
We’ll see.
There a reason why you would do 9.5 width up front? Noticed most do that width up front. I want to do a 10”
Keemaca
Mario
2024 Supra
We sell a lot of both, show wheels and then performance wheels. People usually alternate between the two.
-Josh
What’s the recommended tire width up front if I was to do a 10” I know I want a 35 series sidewall but debating on a 275 or 285.
Munad
Phoenix, Arizona
2024 Toyota GR Supra MT, Red. 2010 Lexus RX350, Black.
That's a good question. I wouldn't say I'm an expert, but from my last couple weeks of research it appears that sizing gets tricky in the front because or our 4 piston brakes. And then you have the chance to hit the suspension strut if you go too wide or too narrow lol. So 9.5 is usually a safe sweet spot for us.
Out of curiosity, why do you want a 10" front? I feel like I have more of an issue keep my rear wheels down and straight than ever losing any traction in the front. The 10" fronts I have seen have been pretty pokey, if you're into that look. I also feel like the pokey look doesn't look good until you're on coils or bags to dial it in.
As for the tire question, you'd have to try them out, but typically 10's run 285/35
My 2 cents. Hope it helps!
Meraki Autoworks
Josh
Orange County, CA
www.merakiautoworks.com
2020 Toyota Supra
We do lot of 275/305, but not for 10 front, unless you're talking about track wheels. That's another topic if you're going to do a squared setup.
-Josh
