MCS 2WR Jacking the CAR when fully turned to one side
NoobRacer
Shuai
2023 Supra MT
Hi, I recently installed the MCS 2WR to my 2023 supra(with ground control camber plate). I notice that when fully turned into one side at the parking state. The car is jacked up a little bit and seems like the full coilover will lift at that position. But I did not notice any issue when driving. Is it normal? BTW, the i got 800lb spring(5") at the front. Thanks
You are seeing the effect caster has when turning the wheel, which will jack the ride height, OEM did the same thing.
