Pulled power on track (tuned and yes, I have an intake manifold), logs attached.
SupraVin
Vin
Hey guys, hoping the hive mind can help me out. Here's my situation, 2020 3.0 currently on a custom MHD tune pulling power 10-15 minutes on track. I have attached the same MHD log I ran for my tuner during a full session today at Dominion Raceway. Temperature was low, around 50deg throughout the day. For cooling I'm running a wagner intake mani, mostly water for both cooling loops, a Verus turbo shield and hood louver. I don't believe this to be heat related as this point but perhaps I'm missing something. I do drive the car pretty hard and can keep pretty consistent 2:05s on VIR full with a PB of 2:03.33. My tuner has not been able to figure it out yet, and the tune I'm running seems to have a target of 22.5psi on the conservative map that I ran today. One other additional notes, car is high miles, recently broke 100k, no major repairs other than oil pump.
You are running 23.9 PSI as your target, and you are running about that much. That is a lot of boost for track use on the stock turbo. Are you on ethanol? I'm assuming no based on the AFR, although your MSV angle is maxing out, so maybe? That is a crazy amount of boost for pump gas for track use.
Tons of ignition timing being pulled as well.
I believe you are going into limp mode because you are maxing out your HPFP at 126* from overboosting 25psi+ and the rail pressure is crashing:
SupraVin
SupraVin
Vin
I was really hoping you would chime in. Your posts and docs have been a life saver in the past, appreciate your input.
I was running a very small amount of E at the request of my tuner. No analyzer or FF kit, just doing the math to keep it around E15-20.
Would you concur that next step is running a milder tune and do you have a recommended MHD tuner that understands track cars?
Edit** I was also noticing the exhaust temps seem to be insane. My buddy on Ecutek compared our logs and he had a 450° difference.
Appreciate your time to look over the logs.
