ticking sound from the front wheels
sams2k
sam
israel
i have a loud ticking sound from my front left wheel under hard fast cornering
i can hear it only when the window is open
in on stock wheels and tires, stock suspension only with front 13mm spacers
any ideas what could make this sound ?
maybe not correct torque for the wheel bolts ? according to BMS its 105 ft-lbs
gdi2290
PatrickJS
Los Angeles, California
GR Supra 3.0 Premium
It took me awhile to figure this one out but its a stock issue that sounds worse with spacers. The real issue is actually the brake disc and is a BMW thing. So BMW owners order a different set without the issue. I've used an Aluminum Alloy (not painted) spacer that got rid of it (brand Motorsport Hardware)
CarGuy11
Pittsburgh
'20 Supra Prem/Assist DS Blue, '16 C7 Z51, '22 Mach-E, '24 Emira
I have it as well and never figured it out. So its the rotor clicking due to the aluminum hub riveted to cast iron ring? I take it the clicks are not harmful then?
