WATER LEAK - UNDER PASSENGER SEAT
stefastn
James
FL
Hey guys, been dealing with a bad water leak the past month. Out of nowhere discovered water leak under the passenger seat, no idea where it’s coming from. Hosed the car down while inside and there’s no visible or audible leaks but somehow there always ends up being a heavy amount of water built up in the carpet under passenger. I wet vac it out and it just keeps happening, I already have a car cover but it still finds its way in somehow. Like it’s coming directly from under the carpet. What should I do?
MrNobody
Internet
Soapbox
Does your passenger door seem heavy? Or if you swing it open and closed quick can you hear water sloshing around?
sup.dc2
JJ
Fontana, CA
Mk5mt. DC2. T4R.
take it in for warranty repairs if it applies to you.
but your water leak is most likely coming from your evaporator housing. The drain tube may be clogged or came off. Do you notice this leak after using the a/c?
jay35
AZ
Toyotas
Is it possible the washer fluid reservoir got damaged when you did the EVS fenders and is somehow leaking into the passenger compartment? Did you check to see if the washer fluid reservoir is empty? Only other thing I can think of that is in the vicinity.
Bug2th
Rich
Folsom, Ca
A91-CF AZ, 1998 GSX
Did take a passenger for a more than spirited ride?
