Wheel Bearing Concern?
calmeda1
Christian
FL
2021 Toyota Supra 3.0 Premium
Lifted my car as a flood preventative due to the hurricane. Everything's good, gladly! Before lowering the car, I decided do a quick look around for any unusual things. The only thing I noticed was that the front-driver wheel spun more than the other if the same amount of force was applied. No noise, and both wheels are stable; just that one spins more than the other. I'll post a video link in a bit, since the site won't let me upload my video.
Is it just me nitpicking or should it be something to look into?
Edit: Link to video
MisterSkiz
Chicagoland
Brake pads could be dragging too. Any noise while driving, or noise increase/decrease while turning?
calmeda1
calmeda1
Christian
FL
You need to take the brake pads out to check bearings for noise, and ideally the brake rotor too. Brake pads will have slight drag on the rotor.
MisterSkiz
Chicagoland
I used to hear a noise a while back. It was a repetitive ticking anytime I took a hard turn. It's the exact same noise in this thread:
https://www.supramkv.com/threads/cl...ming-from-driver-side.6025/page-5#post-295934
However, for some reason it stopped after I changed the tires, and I didn't look further into it.
Well, I can tell you from experience that I had a bad (old heat cycled PS4S) tire that sounded exactly like a wheel bearing on the front of my daily driver.
I replaced both front wheel bearings and noise was still there - then replaced the tires and it went away. The tires looked fine, balanced fine, but they were about 6 years old.
If you are not having the noise any more than its not your wheel bearing - it would get louder over time.
You mentioned that you felt one side spins easier than the other - does the car have a pull in one direction all the time? (regardless of the road - most have are sloped so that water goes towards the shoulder) If you dont have a pull to one side, then keep an eye on the brake dust on one wheel versus the other, and you could even measure the temperature of one front rim versus the other when you come home from your daily commute. This might mean you have a slightly sticking caliper.
But, to be honest with you - I think you might be chasing a ghost and worrying for nothing :)
calmeda1
calmeda1
Christian
FL
Yeah, I do tend to worry over nothing with this car lol. I'll still try the things you mentioned cause why not. Thanks for the advice!
calmeda1
calmeda1
Christian
FL
I checked everything the past week and everything seemed perfect. However, today the repetitive noise I mentioned before started again and it's even louder. It also happens regardless of me turning or not.
4g63T
Bruce
Toronto
370z Nismo
I am experiencing the same issue, just changed both front Wheel Bearings and literally less than 100kms and the sound has come back. What was your resolution?
First suspect in a "wheel bearing type noise" is tyres.
4g63T
Bruce
Toronto
370z Nismo
No way lol!! I hope thats my issue too
