CEL light after MHD Tune
Ryco
Darsiah
North Carolina, Fayetteville
2020 Supra MKV Premium & 2014 Scion FRS
I installed a catless downpipe and MHD stage 2 tune oct 93. I installed the tune today and it was successful flashing and cleared all my codes. I drove the car normal at first and then I started pulling the car to feel the power differences. I even raced my friend's rs3 and I won lol, but after that car was still fine. When I was driving back home from work 3 hours later not in "Sport Mode" I got a CEL and got worried. Help me diagnose this issue.
Here is the code I pulled from it:
- DME active codes -
118001 - Mixture control: mixture too lean.
21B055 unknown
21B056 unknown
- DME shadow (inactive) codes -
30E1C unknown
10D000 unknown
11CF30 - Mixture control: Multiple fault.
24000B unknown
- Misc. information -
MHD build: version 1.47
Voltage 12.54V
Last flashed file : v1.5 Stage2 93oct_98ron
VIN: WZ1DB4C00LW030276
Factory software:
HWEL 3DDE v003_019_006
HWAP 3DD1 v255_255_255
BTLD 48DC v001_011_001
SWFF 5D55 v060_110_005
TPRG 6354 v060_110_005
Current software:
CAFD 2742 v000_171_006
Current PRG (hex): 5D553C6E05
ECU status: -
- Readiness -
Misfire: Complete.
Fuel System: Complete.
Components: Complete.
Catalyst: Not avail.
Heated Catalyst: Not avail.
Evaporative System: Complete.
Secondary Air System: Not avail.
A/C Refrigerant: Not avail.
Oxygen Sensor: Complete.
Oxygen Sensor Heater: Complete.
EGR System: Complete.
62 25 02 00 00 00 04
geert.bieseman
Geert
Belgium
You can lookup the codes (mostly the active ones) here: https://bmwfault.codes/
118001 = Mixture control: Fuel-air mixture too lean
Are you actually fueled up with octane 93?
Here in Belgium, stations advertise with octane 93 but sometimes it is a little bit below the value (as with all tolerances).
Or maybe on an empty tank?
I am always adding octane booster when I fuel up the car, just to be sure. But this is because the tune pushed the car to 'its limits', so it was recommended to use octane booster to make sure I am not getting misfires (knocking sensor kicking in).
But than again, I am not an expert on cars :)
There will be people here who could 'diagnose' this better :)
Ryco
Ryco
Darsiah
Yea, I use 93 pump octane from shells. I dont know how true they are to 93 octane. I can try adding octane booster too see if that helps. Also, I am on half a tank right now when the CEL came on.
cutsman
1972 Austin Mini (VTEC), 2020 Supra, 2005 Cooper S
Hmm, "Mixture too lean" just seems to tell me that the O2 sensor is detecting the changes in flow because of the catless downpipe. Does your MHD tune have an option to not detect the CEL for the downpipe?
Twisted Tuning
www.twistedtuning.com
21B055 unknown
21B056 unknown
30E1C unknown
10D000 unknown
24000B unknown
Voltage 12.54V
Factory software:
Current software:
ECU status: -
- Readiness -
Misfire: Complete.
take a log and monitor your fuel trims and post the log here. thats a closed loop fuel system code.
Ryco
Ryco
Darsiah
That i do not know. I would have to get in contact with MHD about there tunes for this car.
TURBOlence
LA
I want to know too. I'm also gonna go with MHD with a catless DP. What catless downpipe are u running?
BPUKiller
Sam
San Diego
2016 340i, 2020 Supra, 2002 S2000
21B055 unknown
21B056 unknown
30E1C unknown
10D000 unknown
24000B unknown
Voltage 12.54V
Factory software:
Current software:
ECU status: -
- Readiness -
Misfire: Complete.
This is an old thread, but did you ever resolve this issue?
