CEL Light :(
Raskita
Carlo
M235I, Z4, Fj Cruiser, Clarity, Highlander, Supra
Just recently installed Titan down pipe with Fabspeed O2 Spacer. After driving about 50 miles, I received a CEL light.
I ran my OBD2 Scanner and received P0136 & P0141 Heated Oxygen Sensor - Circuit malfunction code.
I tried clearing it with my OBD2 tool however, the status of the code is Permanent. How can I clear this code? Will a tune help me in this situation?
Need to service car soon and need to remove this CEL before bringing to the dealer.
============1==============
P0136
Raw code: 0136
ECU: Engine control unit
Status: Permanent
OBDII: Heated oxygen sensor (HO2S) 2, bank 1 - circuit malfunction
============2==============
P0141
Raw code: 0141
Status: Permanent
OBDII: Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit malfunction
============3==============
P0141
Raw code: 0141
Status: Pending
============4==============
P0136
Raw code: 0136
Status: Confirmed
============5==============
P0141
Raw code: 0141
Status: Confirmed
kona61
Josh
San Bernardino-ish, CA
P0136
Raw code: 0136
Status: Permanent
P0141
Raw code: 0141
Status: Permanent
P0141
Raw code: 0141
Status: Pending
P0136
Raw code: 0136
Status: Confirmed
P0141
Raw code: 0141
Status: Confirmed
Yes a tune will get rid of the CEL, BUT it will also make your warranty disappear. Frankly, I would just live with the CEL as it is unlikely to cause warranty issues without a tune.
Raskita
Raskita
Carlo
So it will be fine bringing the car to my dealer even with that CEL code?
Does a piggyback tune be a good alternative? Just so I do not see any CEL when driving, and then when i do need to go to a dealer I can just removed it prior to having it serviced.
kona61
Josh
Maybe not "fine" per-se. If you have any mods to the car you really shouldn't be taking it to the dealer for anything, and if you do it should be put back to stock as much as humanly possible.
Camus
Daniel.
Elk Grove, California
2020 GR Supra , 2021 M4 Base.
Maybe removing the battery for a couple minutes will clean up the code? Just before bringing the car to the dealer?
Raskita
Raskita
Carlo
Will try that to see if it will clear it momentarily.
Raskita
Raskita
Carlo
Nope CEL light still remains. Now debating to go for BM3 tune hehe
kurumi
Northern Virginia
A catted downpipe will give you a CEL-free experience. Anything from AA, AMS, or in my case, PowerNeedy, shouldn't give you a CEL. That's the alternative route to go if you don't want a CEL on a stock DME.
Green Bay, WI
Fabspeed 02 spacer in my experience will 100% give you a cel stock, with a piggyback tune, and with a flash tune.
You can reset the code with a code reader, JB4 app, Ecutek, etc but it will come back 2-3 days later
Only fix permanent is go catted DP or remove the spacer and get a flash tune. Either way you might as well take the spacer off and launch it into outer space
Raskita
Raskita
Carlo
CEL light came off this morning but expecting it to comeback. Planning to remove the Fabspeed Spacer and launch it to outer space lol
Zoopra
Jordan
San Diego
A90, TRD Pro Taco
Thatā€™s too bad about the fabspeed spacer. The concept seems like itā€™d work.
Axix23
GA
live with the Cel on a brand new Supra? That shit would bother the hell out of me. I remember back in the early 90ā€™s when were doing motor swaps on hondas and didnā€™t know how to get rid of the cel and just lived with it for years. Hahaha
Zoopra
Jordan
San Diego
A90, TRD Pro Taco
If it makes you feel any better, I put my catless downpipe on today. Took about 20 miles of driving for the CEL. Ecutek coming next week.
Raskita
Raskita
Carlo
Planning to do the same by next week aswell. What made you choose Ecutek over the others? Debating which tune to get.
