Charge pipes
a90moe
Earth
MKV Supra
My Forge kept leaking and popping off, after a long process I finally got a refund (still out install and shipping money). I went back to stock with no issues. I'm on E40 and run road course as well. I've had a handful of people message me about the Forge and FTP leaking and every person has gone back to stock after going through weeks/months of issues. I would be willing to bet there's people who've installed them and don't regularly log so they may not even notice a small leak.
Highly recommend avoiding Forge and FTP, The amount of people who have messaged me about the same thing is the reason why I'm posting.
Where is yours popping out exactly?
Lower or upper pipe?
Mark5825
Houston
2020 Supra, 2017 Mustang
Where the worm clamps hold the 2 pieces together. I had multiple leaks from the larger and smaller clamps. Switched to T-bolts and they were also backing off after only a couple days.
Axix23
GA
Wow, if it’s backing out on t-bolt clamps too.. holy cow. Idk what to say!!
a90moe
Earth
MKV Supra
I'm on Pure800 and ran a highboost 26psi tune with spikes going up to 29psi.. Now on low boost and never had an issue
Marin@MarinTuned
Scottsdale AZ
2020 GR Supra
I run 30+PSI (gauge) on my car in the heat and mine holds on my forge pipes. But ive seen some people have issues at lower pressures. I did put a t bolt clamp on the lower connection the last time it popped off and its been pretty solid ever since.
jchall30
jchall30
KY
2021 Toyota Supra A91 Refraction 2021 Lexus UX250H
What T bolts are you guys using? Never have used them before.
jchall30
jchall30
KY
Anyone have any links to somewhere that sells them? Also what size would I need for the FTP/Forge style pipes?
Supra Werty
Will
Arizona
2021 supra
I went with injen. I liked the fact that the entire pipe is 2.75". Some of these other brands are using a smaller diameter pipe at the turbo connection and then stepping up to 2.75".
