Front Camber Adjustment feeling light in the front when accelerating
Deleted User 191538
This is for my 2021 Supra
Sitting on Verus Camber Plates and Eibach lowering springs.
So I had a small camber adjustment to the front of the supra and it drives great, but it definitely feels a bit lighter in the front when accelerating and even turning...
I"m sure it's because of the impact the tire has. But...Is there a way to help with that such as harder Shocks, or additional downforce to the front. I know downforce would only help in the turns? But anything I can do "with the camber the way it is" to make the front not feel like it's lifting?
Can you share your alignment specs?
Boston
22'Supra 22'BRZ 18'Civic Si
I have the same feeling with SPL lca installed recently. I am sitting at 3degree F and 2degree R (Camber) 0 toe F&R. When I drive straight on highway I feel center deadzone is more. The force back is also different when I turn comparing to stock.
digatron
Kevin
Southern California
A90 Supra, FA20 wrx
you probably mean -3 and -2
Too many variables. Agree with Bryan ? Can you share your alignment? Likely more than just camber. If it’s the alignment.
