jgardner150
- Thread starter
- #1
Has anyone emptied their fuel tank? If yes what method did you use / how hard was it?
Reason I ask is that I was thinking about emptying my tank when I pull my car out of storage in the spring. I currently have it completely filled with 93 *E10 with stabilizer added, best I can do short of finding non-ethanol fuel to fill up with. My thought is to empty the old gas out to avoid running 5+ month old fuel, probably will use it in stuff like lawn equipment that don't care so much about. Yes I'm probably being overly cautious I know... but if there is a somewhat easy way to do this it's just piece of mind for me...
I had a thought to re-use my factory fuel line I removed when I added the Fuel-It ethanol sensor, and just lengthen it with some spare fuel line so I can feed that into a gas can... Then somehow trigger the fuel pump to run manually to pump it out the tank. In the past I would just jump the fuel pump relay to do this, but I'm guessing it's not that easy on the Supra, maybe it is??
I also have an Autel scanner, but pretty sure the Supra isn't supported on it (to be able to manually trigger the pump).
