Natek
- Thread starter
- #1
https://www.repairerdrivennews.com/...-warnings-on-2020-camry-supra-bumper-fascias/
basically, you cant.
I'm reading it as, solvents and heat can perhaps cause shrinkage/expansion and thus may affect the position/orientation of the sensors. If that's a correct interpretation, then, I'd assume PPF/wrap would be OK.Stated that the bumpers can only be painted once, if that's the case won't PPF or vinyl wrap affect the sensors also?
27. The Pre-Collision System (PCS) with Pedestrian Detection (PD) is designed to determine if impact is imminent and help reduce impact speed and damage in certain frontal collisions involving a vehicle, a pedestrian or a bicyclist. PCS w/PD is not a substitute for safe and attentive driving. System effectiveness depends on many factors, such as speed, size and position of pedestrian and weather, light and road conditions. See Owner’s Manual for additional limitations and details.
