Left High Beam Malfunction - Help
mokleen
San Diego
2022 Toyota Supra 3.0 Premium
Hello!
Long term member here.
I’ve had the car since nov 2021, it’s a 2022 MY and I have 20k miles on the odometer.
Welp, today I turn the car and I get hit with this error:
My gut tells me something electronically is just stuck or bugging out.
anyone know a way to essentially hard reset the vehicle?
Any known solutions?
thank you in advanced.
garudathree
ny
none
headlight control module needs to be replaced, not the little one for the DRL.
garudathree
ny
none
yeah, but IIRC it needs to be programmed to your car. you should still be under warranty, let the dealer take care of it?
mokleen
mokleen
San Diego
Interesting, what the heck does this thing do if everything is still operating properly?
Eastwood
also, do I need to revert everything to stock before handing it over to the stealership?
Switch back to OEM ECU with stock flash/rom and tell them not to update it just in case.
Hopefully they don’t hassle you with a catless DP.
Convinced
Vince
2023 Supra
Did this ever get resolved? Hopped in the car today day and suddenly got warnings for turn signal, high beam, and low beam malfunction.
Seem to be in the same boat as you since they all seem to be operating properly
